Washer bottle pump
385 views 1 reply 2 participants last post by  titchy
#1 ·
Hi anyone have an idea on the best way to access my washer bottle pump on my 08 titanium x
Many thanks Martyn
#2 ·
hi, if you jack up and support the front of the car, then remove the engine undertray and the shield from under the radiator you should have access to the pump, if you need to remove it disconnect the wiring plug and hoses from the pump then prise the pump from the washer bottle.
