98 mustang convertible v6 airbag code 24 help
2 replies to this topic
#1 Ronnie d
Ronnie d
  • 2 posts
  • Vehicle Driven:98 Mustang
  • Name:Ron
Posted 29 December 2016 - 01:36 PM
98 stang, convertible,v6 airbag light flashes code 24. had disconnected battery due to the fan motor would come on with ignition off parked in the garage, Did this 3 times and has not happen again. have not found reason for the fan motor to have done this. After connecting the battery back up and the car sat for a week, I move the car to a different parking spot, I notice the light flashing and don't know what to check for this 24 code.Thanks for any help.
#2 siruncle
    munched many bananas
  • 18456 posts
Posted 29 December 2016 - 02:08 PM
I think this is 24, Safing Sensor Output Feed/Return Circuit Open Circuit Or Low Resistance In Airbag (SRS) Sensor
Pretty vague tbh...
If you've been moving the front seats while fitting parts, it could be the seatbelt pretensioners.
Normally on fords, they are the yellow plugs under the seats. Keep the keys out the ignition for 20 mins, and while doing, but unplug and plug each connector under the front seat a couple of times. Probably the most common cause of airbag light.
  • Ronnie d likes this
This is Ford country, listen quietly and you can hear Vauxhalls rusting :)
#3 Ronnie d
Ronnie d
  • 2 posts
  • Name:Ron
Posted 29 December 2016 - 11:13 PM
Thank you for the info, I did look under the front seats and there is no yellow connector, the right side has no wire to the belt that bolts next to the tunnel and left side has a blk small harness coming out of the belt and going right back under the console, don't know if a convertible is different as this is what i have. I have ask this same question on other sites and no one has been able to help, I guess I got me a real problem. Again thanks for your input.
