Front & back windscreen washers not working
13 replies to this topic
#1 yanna1
yanna1
  • 13 posts
  • Vehicle Driven:Focus zetec 1.6
  • Name:Chris
Posted 20 March 2017 - 09:14 AM
Hi,
I have a 2013 Zetec mk3 Ford Focus and the front and back windscreen washers are not working. I believe that there is a blockage somewhere because I can hear the pump but there is only a dribble coming out.
The car is booked in but not until the end of next week and its doing my head in not having any.lol
I was hoping somebody might know of a way of unblocking the pipes with out going down the removal of the wheel and arch etc to get to the filter. Maybe a some sort of drain unblocker.
Any ideas?
#2 yanna1
yanna1
  • 13 posts
  • Name:Chris
Posted 20 March 2017 - 10:20 AM
Hi,
I finally manage to unblocked them using a flattened staple.
Does anyone have hints or tips about preventing this from happening again?
Edited by yanna1, 20 March 2017 - 10:21 AM.
#3 Mondy zetecs
Mondy zetecs
    Clever Clauggs
  • 2005 posts
  • Name:Harry
Posted 20 March 2017 - 10:58 AM
I only use water as screen wash turns to gel and bungs up but only problem
is water freezes.
#4 yanna1
yanna1
  • 13 posts
  • Name:Chris
Posted 20 March 2017 - 01:46 PM
Thanks. Will try using less screen wash.
#5 siruncle
    munched many bananas
  • 18457 posts
Posted 20 March 2017 - 08:36 PM
You can normally remove jets, and disconnect from the pipes. If they are heated, there may be some plugs to disconnect.
You could then use some compressed air (they sell this in poundland near headphones, usb leads etc) to reverse blow down the jet, any crud should come out the end of the jet the screenwash normally goes in by, so it will be out the system, not ready to block the jet again.
It may be possible to just disconnect the pipe and blow down them in situ?
With regards screenwash, when mine runs out, i chuck 2x 1 litre bottles of holts all seasons screenwash concentrate in, and fill to the brim with water. I've never had gelling issues. I probably top up once a year.
  • DaSingh and Mondy zetecs like this
This is Ford country, listen quietly and you can hear Vauxhalls rusting :)
#6 yanna1
yanna1
  • 13 posts
  • Name:Chris
Posted 21 March 2017 - 07:46 AM
Thanks for the advice. Will defiantly give that a go.
#7 DaSingh
DaSingh
    Nottz Megger
  • 1830 posts
  • Vehicle Driven:Mondeo MK3
Posted 28 March 2017 - 09:19 PM
Have exact same problem so is it the jets blocked or gel formed in bottom of the water bottle?
Sent from my SM-G930F using Tapatalk
2004 Mondeo MK3 1.8 Zetec Hatchback in Panther Black
2013 Focus MK3 1.0 (125PS) Titanium in Panther Black + City Pack
#8 yanna1
yanna1
  • 13 posts
  • Name:Chris
Posted 29 March 2017 - 09:53 AM
I managed to get mine unblock using a paper clip  to try and clear anything from the jets. Then just keep trying to use them till they eventually started working. Once they started working again I topped up with just waster and flushed it through a couple of times hoping to clear any blockages. So far so good.
However the sensor that tells you when its near empty does not work now. When I first got the car I was missing that rubber grommet thing that holds the two parts together. Took the car back and they fitter the grommet plus fitted a new sensor for some reason even though the sensor was defintaly working.I used to get a consent warning the level was low.
That was in February. Its back in today to have that sensor checked. Not sure how they could fit a new one and for it not to be working.
Edited by yanna1, 29 March 2017 - 09:54 AM.
#9 Mondy zetecs
Mondy zetecs
    Clever Clauggs
  • 2005 posts
  • Name:Harry
Posted 29 March 2017 - 12:25 PM
If yours is mondeo mk3 there is a filter inside the rubber bung on the side of
washer bottle that clogs up. The rubber bung outlet just pulls off to clean.
Edited by Mondy zetecs, 29 March 2017 - 12:26 PM.
#10 DaSingh
DaSingh
    Nottz Megger
  • 1830 posts
Posted 29 March 2017 - 12:26 PM
Iv took the jets out and they look fine but both front and back have same problem so I think I'm going to try disconnecting the water bottle altogether but before I do is there a fuse I should check.
The wipers starts as soon as I try to use the jets but don't know if it is separate.
