ObdII scanner and application for dpf differential pressure monitoring
2 replies to this topic
#1 gergo7633
gergo7633
  • 2 posts
Posted 11 April 2017 - 08:43 PM
Dear all,
Can I use forscan mobile or torque Pro for android to monitor dpf differential pressure values using a generic elm327 Bluetooth module?
The car is a Galaxy 2011, 2.0L 140HP, dw10c engine. And where can I find the obd connector?
Thank you for your help.
Gergo
#2 siruncle
    munched many bananas
  • 18366 posts
Posted 15 April 2017 - 08:34 PM
can't say what you can or cannot do with mobile apps via obd, but i can tell you they normally fit the port under the steering wheel, follow the cowl down and past the cowl onto the lower dash panel, it is often covered by a similar shape or rectangular cover. Might also be found in a stowage tray between the lower steering wheel cowl and the door.
This is Ford country, listen quietly and you can hear Vauxhalls rusting :)
#3 gergo7633
gergo7633
  • 2 posts
Posted 19 April 2017 - 05:07 AM
Thank you. I have found it.
