Wet Drivers Side Floor
13 replies to this topic
#1 D4VIE
D4VIE
  • 19 posts
Posted 17 September 2008 - 10:16 PM
Hi Folks,
The drivers side floor of my car is very wet under by feet. I do not see any damage to seals or missing gromets etc.
Is this something others have noted and if so what are the likely causes. I will happy check all suggestion.
Davie
#2 Bin_Man
Bin_Man
    Resident buffoon
  • Forum Moderator
  • 4,192 posts
  • 42 thanks
Posted 18 September 2008 - 08:36 AM
Have you checked the gromet around the steering column? It can detach and that would let in quite a bit of water. There aren't that many places water can get in, so try there first and also check the door seals at sill level.
Bin_Man contains strong language and scenes of a sexual nature
The nice thing about Marmite, the really GREAT thing about it, is that if it gets stuck in customs for four years, goes well past it's use-by date, becomes rancid and the bacteria develop to a point where a system of local government is in place, they have free housing for bacteria with families, all the little bacteria go to school and the more inquisitive bacteria have invented both the digital watch and Corby trouser press - it will STILL taste absolutely FOUL !!!!
#3 icedune
icedune
  • 348 posts
Posted 18 September 2008 - 03:04 PM
Check:
1) Rubber door seals - sometimes have a gap in them
2) Door cards - the sticky stuff that holds the foam is known to perish and let water in.
3) As above - the gromet
4) The boot - sounds stupid, but water runs from leaky rear lights, especially if you park on a slope.
5) If no joy it could be a gap in your windscreen seal or bulkhead.
I had this problem, tore up the carpets, underlay, sound insulation and still never found the damn leak. However I blasted a ton of sealant over everything possible and it seems to have solved the problem!
Mondeo Mk2 1.8 Zetec
Blasting down the M40 with the stereo set to 11
#4 sdnm123
sdnm123
  • 1,152 posts
  • 1 thanks
Posted 19 September 2008 - 09:03 AM
i had this problem on my mk1 and it turned out to be the weather strip on drivers door was leaking door was filling up with water and running out the bottom in to the floor
mondeo mk3 graphite black
#5 D4VIE
D4VIE
  • 19 posts
Posted 22 September 2008 - 06:01 AM
Hi Folks,
I had a look at this at the weekend and think i'm closer to solving this one.
with the carpet pulled back and the footwell cover removed i can watch water running down the inside of the car to the floor. To get this to happen i need to pour the water on the windscreen where it passes into a channel at the corner and down behind the wing. Similarly if i pour the water through the plastic vents covering the wiper assemble the water there makes its way naturally behind the wing. This is meant to happen but obviously there is something wrong in that area. Tonight i plan to remove the plastic inner arch cover to see what is actually happening up there. Hopefully it will be obvious what is wrong when i get to see it.
Davie
#6 philmon
philmon
    mondeo st200
  • 9,070 posts
  • 61 thanks
Posted 22 September 2008 - 09:34 AM
let me know when you find it, cos i have same problem.
#7 D4VIE
D4VIE
  • 19 posts
Posted 23 September 2008 - 07:32 PM
Hi mate,
I haven't done anything yet but i did have a look tonight and here is what i saw. Why i removed the inner arch cover everything looks as it should. When you pour some water on the screen etc it makes it's way down the A-pilar and onto the ground. On the A-pilar and Inner wing there are a couple of seems where sections are joined together. I believe it is through these seems that the water is getting in. The water runs right down these and at a couple of places there are possible gaps due to the forming of the sections. It is my intension to put some silicon sealant down these joints on both sides of the car. There is no harm in doing this and i think it is likely to be the cause on my car. You can let me know what you think when you look at your own.
#8 philmon
philmon
    mondeo st200
  • 9,070 posts
  • 61 thanks
Posted 24 September 2008 - 11:01 AM
hi,
i've just done what you said i've put sealant around all the seams so i'll let you know if it has stopped the leaks, thats if it rains cos its been sunny the last couple of days.
#9 philmon
philmon
    mondeo st200
  • 9,070 posts
  • 61 thanks
Posted 02 October 2008 - 11:44 AM
well its rained for a couple of days now, including a very wet trip to sheffield and huddersfield and no water whatsoever has got into the footwell , so the sealant has done the trick. :L :L :L :L :L
#10 graham2225
graham2225
  • 111 posts
Posted 20 October 2008 - 07:49 PM
my mk2 estate had the same problem but the leak came from the sunroof drain pipe(black+white pipe haway the lads)the roof interior was damp at the top corner of windscreen and damp floor .just had to re attach the pipe by carefully removing roof interior at corner and sunroof seal hope this helps :driving:
current car
FORD MONDEO MK3 2.0 ZETEC ESTATE
EXTRA MODS footwell lights,middle interior light,clear indicators,chrome vents
past cars
FORD MONDEO MK2 1.8td ghia estate
mk2 1.8td lx estate
ford escort 1.6 estate
