wiring up heated seats
43 replies to this topic
#1 graemewelch
graemewelch
    MEG Captain
  • 5,282 posts
  • 1 thanks
Posted 19 October 2008 - 07:53 PM
hoping to get me heated seats wired up at the weekend, car is pre facelift as are that seats. there is no wiring for them behind the dash, has any 1 done this befor or got any advise
#2 dazedconfused
dazedconfused
  • 1,706 posts
  • 7 thanks
Posted 19 October 2008 - 08:06 PM
suspect we may be on our own on this one bud :)
have to get me thinking cap on and do some diagrams
2005 TDCi Saloon, Stardust Silver (NOW SOLD)
#3 Ben_W
Ben_W
    6 cylinders.....its the future ;)
  • Forum Moderator
  • 3,758 posts
  • 10 thanks
  • Vehicle Driven:2.5 V6 Zetec-S
Posted 19 October 2008 - 08:15 PM
compuwiz is your man
Stardust Silver Mondeo Zetec-S Saloon - Lower than than Markyg's morals.....
Hatch for a show, Saloon for a pro........a funky green buggy for everything else!!
Buggy, buggy, buggy!
#4 L11XXY
L11XXY
  • 3,238 posts
  • 74 thanks
  • Vehicle Driven:ST220
  • Name:Alex
Posted 19 October 2008 - 08:46 PM
The wiring diagram isnt that complicated...
You'll need to take 2 power wires from Pin 14 on plug c500 on the fuse box.
Then a wire from Pin 9 on the light switch plug
Then a solid earth wire that splits into 2 for each of the switches.
From then on in the power wires goto pin 8 on the switches, then exit out of pin 1 to the seats.
These then go into the large black plug under the seats which is known as C60. The individual plugs thereafter are C60a, b, c, d etc etc...
POwer goes into C60 on the driver side, Pin 9, into Pin 1 on C60d, into the seat heater, exits out to pin 2 on C60d then to pin 10 on C60, round to pin 17 C60 into Pin 1 C60h round the backrest heater and exits out to Pin 2 C60h then to pin 18 on C60. That then goes to earth...
I dont think that we can post up pictures of the wiring diagram re: Forum rules, but i am sure that someone can E Mail a copy to you.
02 ST220,Retro Fitted Touchscreen Nav,Bluetooth, Voice Control,Climate Seats, OEM DVD Entertainment, RSE System, Xenons, Focus Sub Lighting
Ford IDS Services available - Touchscreen Sat Nav Repair & Diagnostics - Bluetooth Diagnostics - Electrical Upgrades & Retrofits - Mobile Service may be available
Call Alex on 07955 406 446 - Updated 17th May 2014
#5 dazedconfused
dazedconfused
  • 1,706 posts
  • 7 thanks
Posted 19 October 2008 - 08:52 PM
got the wiring diagram (attached), thanks mate
Would I be right in thinking that if Graeme's car has the floor loom fitted, this is the wiring from C60 & C61 (under seats) to C71 (right hand A-pillar)?
So, theoretically, only the wiring from the switches to C71, and to the central fusebox is needed? I presume the grounds (pin 4 of switches) can be connected to any ground point?
#6 compuwiz_uk
compuwiz_uk
  • 18,607 posts
  • 326 thanks
  • Vehicle Driven:2001 1.8 Mk3 Mondeo
Posted 19 October 2008 - 09:27 PM
if you dont have the wiring plugs for the switch's then the female miniblade crimps from maplins do the job perfectly :L
just wire em up on the switch like in the piccy & then your sorted :) ( thats how my mota & also 4 other local meggers heated seats round here are wired & working well - well 3 of em are, the last one sadly does not have heaters in the seats but the power is getting to the seats fine :} )
#7 dojj
dojj
    Resident Wrestling Legend
  • Gold Member
  • 3,370 posts
  • 12 thanks
Posted 20 October 2008 - 09:08 AM
is this the same set up for the facelifted cars?
as in if i wanted to put facelifted heated seats into my pre facelift motor and use the cooling feature in the facelifted switches would this work?
there are only 6 wires on the facelifted switches though not 5 a side like the pre versions :(
mk3 mondeo ghia x estate 2.0 auto with:
362mm 6 pot ap stoppers lurking behind some 8 x 18 comps
tv fitted to facelifted dash + headrest screens for both kids
full st kit + powerfolds w/puddlelights with jp stainless exhaust
shonky n/s/f rattle fixed by totd whoopie!
most of the chrome bits done (still looking for fog light surrounds)
#8 compuwiz_uk
compuwiz_uk
  • 18,607 posts
  • 326 thanks
Posted 20 October 2008 - 09:15 AM
no, the facelift setup is different.
that has power going to each seat all the time & then a feed from the switch's which sends a variable signal to the seats to let it know what setting to use.
basically its doable but would involve re-wiring the floor loom too :L ( L11XXY will probably be your man to find out how to do it :) )
#9 graemewelch
graemewelch
    MEG Captain
  • 5,282 posts
  • 1 thanks
Posted 20 October 2008 - 09:54 PM
cheers big fella, will try and get some pics so can do a how to when we wire them up
#10 dazedconfused
dazedconfused
  • 1,706 posts
  • 7 thanks
Posted 20 October 2008 - 10:11 PM
what guage of cable is needed mate, they use much juice?
