Recent Topics
BIG PUDDLE IN THE FOOTWELL ???
7 replies to this topic
#1 mark1316
mark1316
  • 75 posts
Posted 26 October 2008 - 07:25 PM
Helllllp
Guys and Girls I have a swiming pool im my passanger footwell. Brings back the old Orion days with the dodgy battery tray. Any Idea where the drain holes are under the bonnet or anywhere else I should look ? We have had a sed load of rain up her but mine is dry and  THE mrs IS SWIMMING LOL We park nex to each other by the way .
Any help on this guys and girls ?
2002 MK3 TDDI bog standard (Not for long) :flipoff:
1800 silver top blue led,s white dials and inducted to the moon ( gone to a new home )
18td for the mrs (RIP) The car not the Mr,s  :BEEP:
#2 MScotts
MScotts
    Never knowingly understood
  • Administrators
  • 23,117 posts
  • 20 thanks
Posted 26 October 2008 - 07:33 PM
Many posting about this in the past point the fault to be the pollen filter.  That might be the issue wi yours matey.
4-wheels - LPG converted ST200 Saloon Ltd Ed No.177
2-wheels - BMW Motorrad
#3 mark1316
mark1316
  • 75 posts
Posted 26 October 2008 - 07:59 PM
Ment to say its a 18TD. The pollen filter? you mean the water is filling up in there ? and finding its way to the passenger footwell ?
#4 graham2225
graham2225
  • 111 posts
Posted 26 October 2008 - 09:32 PM
mine came from sunroof drain pipe that was not attached.my interior roof was wet on top at windscreen corner then ran down to front door well hope that helps :driving:
current car
FORD MONDEO MK3 2.0 ZETEC ESTATE
EXTRA MODS footwell lights,middle interior light,clear indicators,chrome vents
past cars
FORD MONDEO MK2 1.8td ghia estate
mk2 1.8td lx estate
ford escort 1.6 estate
#5 TDCi 160
TDCi 160
    Gavin T
  • 9,256 posts
Posted 26 October 2008 - 09:46 PM
Quote
Had the same problem on my old 2002 Focus. Some idiot had been messing around with the pollen filter and removed it, but had then failed to refit it properly and the panel under the windscreen wasn't sealed properly. Water then gets in and runs down into the heater blower and seeps through a little drain plug at the bottom of the blower housing. Check all round here, and around the pollen filter. It may need taking out again and sealing properly.
My car photos
Radiant Red Mk2 Mondeo Zetec 2.0
#6 Mal
Mal
    Uncle Nasty
  • 9,043 posts
  • 1 thanks
Posted 26 October 2008 - 10:53 PM
http://www.mirez.co.uk/WaterProbs.htm
ST220 55plate Saloon Final Facelift in Performance Blue.
Honda Civic 1.8 Vtech Executive.
#7 mark1316
mark1316
  • 75 posts
Posted 27 October 2008 - 09:54 AM
Cheers guys
I will get this sorted at the weekend
mark
#8 Muso
Muso
    Newbie
  • 3 posts
Posted 27 October 2008 - 01:32 PM
Hi,
I had the same problem, water getting into the passengers footwell. Fortunately, the problem raised after I replaced the pollen filter so I knew where to look. The problem was that the rubber between the pollen filter base and the car was deteriorated due to aging. I took off the filter base by removing the two nuts that fix it to the car and replaced the rubber with a new one. Up to now, the problem seems to be solved.
Additionally, I had another water leak ,but in this case the water came in from the footwell side. I found that this leak was originated in the upper windglass rubber. I put sealant in the rubber and it seems to have stopped.
Hope this helps.
