Dip beam not working
5 replies to this topic
#1 cornfrog
cornfrog
    Newbie
  • 3 posts
Posted 06 March 2009 - 08:50 AM
Hi guys. I'm new to this and a bit raw so i'll try and explain as best i can.
I have a 1.6 petrol mondeo 97 on a P plate.
The problem is, that i have high beam and what looks like side lights (very low light next to the indicator) but the normal driving/dip beam have gone. I changed the switch on the dash and checked all the fuses and it's still the same (no dip beam)
I was told to check the relay but i've no idea how to do that or even what it looks like.
Can anyone help? Please
Hugh
#2 stevieb12345
stevieb12345
    MEG Admiral
  • Forum Moderator
  • 5,501 posts
  • 145 thanks
Posted 06 March 2009 - 10:54 AM
Which fuse box did you check? are they not working on both sides?
#3 cornfrog
cornfrog
    Newbie
  • 3 posts
Posted 06 March 2009 - 11:02 AM
Hi. Yes it's both sides that are out and i checked the fuses under the bonnet next to the battery and all the fuses under the glove compartment and they all work. Is this starting to sound expensive?
#4 stevieb12345
stevieb12345
    MEG Admiral
  • Forum Moderator
  • 5,501 posts
  • 145 thanks
Posted 06 March 2009 - 11:12 AM
There are two brown 7.5 amp fuses number 15 and 16 in the engine box which you have checked and a dipped beam relay also in the engine bay fuse box! its R9
#5 cornfrog
cornfrog
    Newbie
  • 3 posts
Posted 06 March 2009 - 11:33 AM
Job done, thank you for your help. I pulled relay R9 once i found the diagram under the cover, i pulled it out cleaned the pins cause they were a bit crusty, put it back and i now have dip beam.
It was a 2 minute job that's taken me hours
Once again, thank you
Hugh
Ps. Going to get one of those manuals now.
#6 stevieb12345
stevieb12345
    MEG Admiral
  • Forum Moderator
  • 5,501 posts
  • 145 thanks
Posted 06 March 2009 - 11:38 AM
No probs. :L Its always the simple things. The hayens manual is really handy to have.
