CRANKSHAFT PULLEY BOLT - IS IT LEFT HANDED OR STANDARD THREAD
8 replies to this topic
#1 veronaman
veronaman
  • 157 posts
  • 1 thanks
Posted 29 June 2009 - 09:40 AM
Before I use heat on the Crank pulley bolt, just like others to confirm that its not a left handed thread.
Thats for a 1997 1.8 Zetec Silvertop
TIA
Wish I hadnt started now!
[color:blue]Mondeo Mk 2 1997 1.8 Verona Silvertop Zetec
Headgasket done, now waiting to finish off bits
Focus Mk 1 2001 1.8LX Blacktop Zetec [/color]
#2 veronaman
veronaman
  • 157 posts
  • 1 thanks
Posted 29 June 2009 - 09:47 AM
Also is it safe to use heat from a butane torch? :kaffeetrinker_2:
Some have said you risk damaging a seal - any comments on this.
Heat up for 3 minutes or so ok?
#3 Fred22
Fred22
    Turbo'd ST24
  • 10,084 posts
  • 30 thanks
Posted 30 June 2009 - 06:25 PM
hi buddy, u will be fine with using heat on the crank bolt, all u want to hit as the crank bolt itself nothing else, if you're worried about the seal just buy another one, its cheap and u should really replace the seal on the timing cover, but u will be fine just use a bit of heat on there from the butane torch and heat it up so that it helps you with removing it, u might get away with out heating it, but best to undo it with a impact gun like the ones u use in your ciggarette lighter port, good luck with it :)
98 Ford Mondeo/Contour v6 :)
my st24 turbo progress
my garage
Dont fcuk with this St24
Shudda bRought a Scooby
#4 Fred22
Fred22
    Turbo'd ST24
  • 10,084 posts
  • 30 thanks
Posted 30 June 2009 - 06:26 PM
oh and yes its turning it right or anti clock wise to undo the bolt ;)
my garage
#5 veronaman
veronaman
  • 157 posts
  • 1 thanks
Posted 01 July 2009 - 11:19 AM
Thanks Fred. The question was put after my first attempt which was with a breaker bar and no heat.
The "elasticity" in the crank bolt was amazing.
Will try heat next and a smile I hope.
Thanks again!
#6 Len Ash
Len Ash
  • 185 posts
Posted 01 July 2009 - 04:25 PM
Standard thread and not that tight - no Loctite either.
Bought new 1999 2L LX Estate in Forest Green 61000 miles, original apart from discs all round and a/c condenser. And cam kit.
Bought new 2000 2L GLX Estate in Ampero Blue, 162000 miles, had new lower arms, sump, a/c condenser, discs all round. And cam kit.
1990 GSX750 FK
#7 veronaman
veronaman
  • 157 posts
  • 1 thanks
Posted 01 July 2009 - 09:12 PM
Thanks Len
#8 veronaman
veronaman
  • 157 posts
  • 1 thanks
Posted 05 July 2009 - 01:35 PM
OK. I can smile now. :) :)
Some progress made.
Crank Pulley Bolt is off.
Thank you Fred and silver st200
Heat works. :thankyousign:
Just need to get a belt on now.
[color:blue]Thanks Fred. The question was put after my first attempt which was with a breaker bar and no heat.
Thanks again! [/color]
#9 Fred22
Fred22
    Turbo'd ST24
  • 10,084 posts
  • 30 thanks
Posted 13 July 2009 - 11:54 AM
no probs buddy glad u got sorted :)
my garage
