Fitting EGR Blanking plate
1 reply to this topic
#1 twhuk1978
twhuk1978
  • 21 posts
Posted 04 September 2009 - 06:49 PM
Bought one from graemewelch on Ebay and wondering if anyone knows of a wiki/tutorial on fitting?
2001 TDDi 2.0 Zetec - Blue
#2 Mik.M.
Mik.M.
  • 411 posts
  • 1 thanks
Posted 04 September 2009 - 06:55 PM
On the EGR valve you will see the metal pipe that goes across the engine.Where this connects to the EGR is where you put the blanking plate. Don`t forget to put the thin metal gasket back too. Clean the EGR using carb cleaner and plenty of old rags,don`t forget to wear washing up gloves.There is an easy to follow guide in the Wiki listed as EGR Clean out. Couldn`t believe the difference it makes. Mik.
03 TDCi 115BHP 6 Speed Facelift Estate in Stardust Silver,run in with 156000 miles on it. 18 inch Focus ST Alloys painted Anthracite Silver,K&N Panel Filter.Genuine Ford mudflaps.Nightbreakers.Footwell Lights.Final Facelift crystal side repeaters.Limo tinted rear doors and rear windows. Graeme Welch EGR Blanking plate & DeCat pipe.Jag Flip key finally done.
Now with new DMF&Clutch and rear wheel bearings + 1 front bearing.M-Tec Drilled & Grooved Discs,Mintex Pads.Front Fogs added.Front Grille blacked.Lower front grille sprayed black.
