Internal cabin light problem
6 replies to this topic
#1 garyclay
garyclay
    Newbie
  • 4 posts
Posted 24 October 2009 - 07:49 PM
Hi, I have an issue with the cabin light. It will work when switched on manually but not when the doors open (yes the switch is in correct position). Any help is really appreciated!
#2 4titx
4titx
    Over Enthusiastic
  • Gold Member
  • 5,374 posts
  • 206 thanks
Posted 24 October 2009 - 07:59 PM
Is there only one cabin light (dont know what model car you have). If footwell lights are on then maybe a connection has come off in the main light.
Does it happen on all doors?
Does the lights reminder operate when door is open and side lights are switched on as this will tell you that the door sensors are working ok?
Phil
LEDs, whats your Watts.
#3 garyclay
garyclay
    Newbie
  • 4 posts
Posted 24 October 2009 - 08:14 PM
Hi, its a 2008 mk4. Rear light works fine its just the front one. Reminder works ok.
The front light doesn't come on when doors open nor when the central locking is open, rear light works fine.
#4 4titx
4titx
    Over Enthusiastic
  • Gold Member
  • 5,374 posts
  • 206 thanks
Posted 24 October 2009 - 08:36 PM
Pull the light fitting out and chcek that all 3 wires are connected. It could also be the actual light switch itself no switching (no contact) when in the door position.
This may seem a bit silly, but try tapping the light fitting quite hard with the switch in the door position. The internal connections in the light fittings are simple point contact connections and they can easily make a poor contact. If you see the light 'flicker' when you tap it you may well have a poor contact in the fitting.
Phil
#5 garyclay
garyclay
    Newbie
  • 4 posts
Posted 24 October 2009 - 08:49 PM
Gave it a firm thump but nothing. Will have to wait for daylight to remove it only managed to remove the perspex cover and that simply accesses the bulb. Is it simply a pull out component as it seems pretty solid?
#6 4titx
4titx
    Over Enthusiastic
  • Gold Member
  • 5,374 posts
  • 206 thanks
Posted 24 October 2009 - 09:05 PM
Yes you have to work at it.
#7 The Artilleryman
The Artilleryman
  • 865 posts
  • 33 thanks
Posted 26 October 2009 - 04:07 PM
Small screwdriver into slot - front of light, behind mirror, to release it.
Mondeo mk1
Mondeo mk2
Mondeo mk3
Mondeo mk3 facelift
Mondeo mk4
Focus mk3 125ps Candy Red with city pack
