Central fusebox/relays
9 replies to this topic
#1 4titx
4titx
    Over Enthusiastic
  • Gold Member
  • 5,374 posts
  • 205 thanks
  • Vehicle Driven:Mondeo 4 Titx
  • Name:Phil
Posted 02 November 2009 - 08:32 AM
In the absence of a diagram locating central relays associated with the central fuse box, has anyone any information on the idents of these relays for this fuse box.
I've not dropped the fusebox yet, but I guess I could soon assess what the relays operated but any information would save this.
Phil
LEDs, whats your Watts.
#2 Mammoth-Mondy
Mammoth-Mondy
  • 1,155 posts
Posted 02 November 2009 - 01:10 PM
Is this what you were looking for Phil :D
Fuse & Relay Info - MK4
HIH
Damo :L
"The object of war is not to die for the good of your country but to make the other bas*ards die for theirs!!"
Juice Green "P Reg" Mk2 Mondeo 2.5 V6 Si Hatchback - GONE BUT NOT FORGOTTEN
JOIN --------"ONE OF THE BEST" if not "THE BEST" mondeo websites going!!!!
#3 4titx
4titx
    Over Enthusiastic
  • Gold Member
  • 5,374 posts
  • 205 thanks
  • Name:Phil
Posted 02 November 2009 - 01:49 PM
Hi Damo, thanks for the reply.
I'd seen that one, unfortunately it shows the fuses and relays for the Engine compartment and Rear, but not the relays for the central fuse box.
I've not looked at the central fuse box and maybe the fuses and relays are separate (though I doubt it) so the relays are not shown or mentioned. Its the relays I'm interested in gaining access to.
Phil
#4 vieplis
vieplis
    vieplis
  • Lifetime Gold Member
  • 655 posts
  • 17 thanks
  • Vehicle Driven:Mondeo Mk1+Mk4
Posted 02 November 2009 - 02:21 PM
Hi, as regards relays in Central fuse box/Auxiliary junction box, FordWiki "Fuse & Relay Information - Mk4" article unfortunately has not yet been completed :kaffeetrinker_2: .
Fuses and relays are separate there, in the sense that relays are not directly accessible, as they are in engine fuse box and rear fuse box. I assume that they must be placed somewhere underneath the plastic housing which reveals fuses only.
Relays present in Central fuse box/Auxiliary junction box should be, as follows:
- battery saver/interior light relay,
- fuel pump relay,
- fuel flap lock relay,
- fuel flap unlock relay,
- tailgate unlock relay,
- rear wiper relay,
- front washer relay,
- reverse light relay,
- front fog lights relay,
- main beam lights relay and, quite possibly, some other.
Unfortunately I cannot provide guidance on how to identify them, once accessed :( .
  • Jarrow Joe likes this
[2007.07. onwards] LHD '2007 Mondeo Mk4 - 2.0 petrol - Tit-X - on the road
[2006.04. onwards] LHD '1994 Mondeo Mk1 - 2.0 petrol - Si ----- on the road
[2004.10.-2009.01] LHD '1993 Mondeo Mk1 - 1.8 petrol - GLX - road life ended
#5 4titx
4titx
    Over Enthusiastic
  • Gold Member
  • 5,374 posts
  • 205 thanks
  • Name:Phil
Posted 02 November 2009 - 02:45 PM
Thanks.
Yes I can hear the main beam and front fog light relays operate so I knew they were down there and of course the relevent fuses for the said circuits so I'll just have to dive in there and find which they are by turning them on.
Thanks again.
Phil
#6 4titx
4titx
    Over Enthusiastic
  • Gold Member
  • 5,374 posts
  • 205 thanks
  • Name:Phil
Posted 08 November 2009 - 02:16 PM
Was going to put my little link in to put the fogs on with main beams, uisng a diode via a switch (so I could turn he facility off) from the switched feed of the relay coil for the main beam, to the relay coil of the fog lamps.
Phew, once I saw that I needed to remove the whole fuse and relay assembly to be able to open up the relay compartment, I'd need to power the relays to find the appropriate ones to link. I guess I could trace it from the fuses for the relivent main beam and fog light relays easily enough. Maybe I'll wait a few months till I get a few more miles on the car but I'll definitely do it.
When do we expect a real wiring/circuit diagram to be available??
#7 vieplis
vieplis
    vieplis
  • 655 posts
  • 17 thanks
Posted 08 November 2009 - 08:03 PM
They are available for money at Ford ETIS website. As regards other sources, there's no sign of Haynes manual yet :( .
#8 4titx
4titx
    Over Enthusiastic
  • Gold Member
  • 5,374 posts
  • 205 thanks
  • Name:Phil
Posted 08 November 2009 - 09:34 PM
Thanks. Mmm I wonder at what cost.
I guess the Haynes will be around at 3 years old, so next year..
#9 JimmyF
JimmyF
  • 1 posts
  • Vehicle Driven:Mondeo Mk4 Edge
  • Name:James Firth
Posted 28 October 2011 - 12:38 PM
Hi, Have intrest in your issue as I have same - An Edge now fitted with spots and all seems connected but fails to work! Have you got issue resolved and if so was the relay cause? Cheers.......
#10 4titx
4titx
    Over Enthusiastic
  • Gold Member
  • 5,374 posts
  • 205 thanks
  • Name:Phil
Posted 28 October 2011 - 01:01 PM
Oh this is an old thread James.
You say you have fitted spot/foglights? Have you fitted a new lights switch assembly which has the foglight pushbutton?
