Mondeo 2002 tdci goes into limp mode.
4 replies to this topic
#1 tomwells
tomwells
  • 12 posts
Posted 03 June 2010 - 07:07 PM
yes give me a vauxhall vectra any day.
#2 BaldiGit
BaldiGit
  • 15 posts
Posted 27 August 2010 - 01:01 PM
Did you get around this problem? As I have a 2002 Mondeo that's doing exactly the same and has the same error codes. I have done a leak off test today and all 4 injectors leak off the same amount of diesel...!!! But I'm fast comming to the same conclusion as you, that it's a air leak in the fuel line. As when doing the leak of test, every now and then a bubble came down the leak of pipes.
#3 mondeo2674
mondeo2674
  • 454 posts
  • 11 thanks
  • Vehicle Driven:Mondeo mk3 TDCI
Posted 27 August 2010 - 07:45 PM
first thing change fuel filter! 2nd thing replace fuel line pipes going to and from the filter!
Mondeo MK3 TDCI 2002, Bluefin,De-Cat,EGR Blanked,K&N
Local Car Audio Specialist in Essex http://caraudioessex.co.uk/
#4 BaldiGit
BaldiGit
  • 15 posts
Posted 30 August 2010 - 01:10 PM
Thanks for the advice, that will be my next attempt at curing the beat. I have just read this thread from the begining and the boost diaphragm sounds a very plausable answer. It is only when I put the car under hard excelleration and only when hot, that limp mode attacks. ie When the turbo boosts most. Now I know old style injection system used to have a diaphragm that increased the fuel mechanically in the pump when the turbo came on boost. But is this true of common rail? I thought this was all controlled by pressure sensors and the ecu? Does anyone have the definative answer..??? If it is a diaphragm..... Does anyone know where to find it as I would have expected a small rubber tube going to the pump somewhere. But I can't see one on mine. Having said that I can't see much on mine under the grime anywho..!!!
#5 bran64
bran64
  • 52 posts
Posted 09 September 2010 - 12:50 AM
Have you cleaned out the egr valve?
