How Do I replace my Aerial Base ??
2 replies to this topic
#1 *Mav*
*Mav*
    MEG Monster
  • 1,200 posts
Posted 08 January 2010 - 08:08 AM
Hi
Dont suppose someone could give me a quick idiots guide to replacing the aerial base pls ?
How do i remove the sunglasses holder so I can get to it ? Also do i need any sealer around the base of the new aerial base ??
Thanks in advance
Zetec-S 130 TDCI
TOO MANY MOD'S TO LIST, JUST CHECK MY GARAGE OUT !!!
#2 smjohns
smjohns
  • 360 posts
  • 1 thanks
Posted 08 January 2010 - 08:17 AM
Don't suppose you have had a quick search around this forum? This has been discussed several times and there is a few guides. Quick summary:
1) Remove front overhead light fitting.
2) Remove aerial mast from top of car.
3) Where the light fitting has been removed you will see the wires connected to the aerial base. Remove these.
4) Unscrew the single bolt holding the aerial base in place and remove Aerial base.
5) Carefully clean the exposed hole to ensure the new aerial base offers a proper water tight seal.
6) Fit in reverse....you may need someone to hold the aerial base until the bolt is firm although it may align on it's own using clips.
#3 *Mav*
*Mav*
    MEG Monster
  • 1,200 posts
Posted 08 January 2010 - 12:01 PM
cheers mate much appreciated, not really searched the forum for it :-)
Thanks again
Zetec-S 130 TDCI
