Mondeo 2003 2.0 tdci zetec cutting out.
17 replies to this topic
#1 justinkeeton
justinkeeton
  • 3 posts
  • Vehicle Driven:ford mondeo
Posted 27 September 2010 - 06:01 PM
can anybody help, I've just bought the above car. It runs perfect but it has cut out completely whilst driving. When it cut out the glow plug light came on. Once Id come to a stop the car started straight away. Think this could be some sort of electrical prob, has anybody had this problem and knows what it is?
#2 Mabok01
Mabok01
  • 3,004 posts
  • 258 thanks
  • Vehicle Driven:Mondeo TDCI 130 2004
  • Name:Michael
Posted 27 September 2010 - 06:35 PM
Hi Justin.
Welcome to Talkford.
Unfortunately the flashing glowplug light is often just an indication as to the fact that you have a problem. I would recommend getting the fault codes read if you also have the Engine Malfunction Light lit as well.
There are a load of things that could cause this. Did the car go into limp mode or cut out completely? Have you had the fuel filter changed recently? We need as much information as possible to help you find an answer.
2004 Hatchback 130 TDCI Inkblue Mileage 443.000 Miles.
Genuine Ford fuel pump sprocket locking tool and pump mounting bolt tool for rent. Refundable deposit by Paypal required.
#3 justinkeeton
justinkeeton
  • 3 posts
Posted 27 September 2010 - 10:02 PM
Hi Justin.
Hi,
thanks for the speedy reply.
It was just the glow pluf light that was on and the car cut out completely. The car is new to me so not sure whether it has had the fuel filter changed recently or not.
Cheers
Justin
#4 Mabok01
Mabok01
  • 3,004 posts
  • 258 thanks
  • Name:Michael
Posted 27 September 2010 - 10:17 PM
A new fuel filter has cured glowplug flashing for a few people on here as has cleaning the EGR valve and inlet manifold for others. It really is hard to say what has caused it. Cleaning the EGR etc is a free if messy way to try and fix it.
Has it happened more than once?
#5 markderby
markderby
    Derby Meets Organiser
  • 3,829 posts
  • 57 thanks
  • Vehicle Driven:Modifide TDCI
Posted 28 September 2010 - 07:53 AM
it all so could be the Cam sensor this would make the engine cut out random and give the engine/coil light
Mondeo Mk3 Ghia X TDCI StarDust Silver Facelift Zetec-S/ST Body Kit My Car Pics
Methanol/Water Injection & Nitrous Oxcide Wheel Power 227bhp / 341lb-ft or 462NM Flywheel Power 266bhp / 388lb-ft or 526NM
Modifide injectors, Big Intercooler, Stainless Steel Decat & Exhaust System ,Forge Pipe Set R-Tech Tuning Custom Ice Install
#6 Lee_TDCi
Lee_TDCi
  • 131 posts
  • Vehicle Driven:Mk3 Mondeo 155 TDCi
Posted 28 September 2010 - 07:08 PM
+1
Get the code read before you cut out waiting to pull out at a roundabout, in rush hour traffic, in the single occupancy lane. I speak from bitter experience, it never happens on a quiet bit of road when you have all the time in the world!
Fiat Punto mk2 JTD HLX 80
Ford Mondeo Mk3 Zetec TDCi 130
Ford Mondeo Mk3 155 Edge
#7 justinkeeton
justinkeeton
  • 3 posts
Posted 28 September 2010 - 07:49 PM
Thanks for the replies, were abouts is the EGR valve located as my cousin who's a mechanic will be having a look at the car for me.
Cheers
Justin
#8 mondeonz
mondeonz
    Member-at-Large, Extraordinary and Plenipotentiary
  • 504 posts
  • 31 thanks
  • Vehicle Driven:Mondeo Mk4.5 TDCI
Posted 28 September 2010 - 08:03 PM
Hi Justin
1st of all congrats on the new Mondy.
As for EGR location and how to, look at http://fordwiki.co.u...d_Clearout_TDCi
I'd start with a new fuel filter and a bottle of Valvoline Synpower Diesel Fuel System cleaner (black 330ml bottle with white sticker) on a full tank.
Following that, I' d do the cam sensor check, EGR cleanout, etc...
Good Luck
Mondeo Mk3 09/2005 TDCi 130 Turnier Carving (+CH), DuraShift 5-tronic, Diamond White
Mondeo Mk4.5 06/2011 2.0 TDCi 163, Wagon ZETEC (+AUS), PowerShift, Panther Black
Focus Mk3 09/2012 1.6 Ti-VCT 125, Hatch Ambiente (+AUS), 5-speed manual, Ingot Silver
#9 salta
salta
  • 5,473 posts
  • 362 thanks
Posted 29 September 2010 - 12:57 PM
the words cut out compleetly mean a compleete failure on all four cylinders.therre are very few reasons which cause this ..total seizure due to no oil or brokenn engine..or what i consider happened your car an electricial failure causing the cut off solinoid on the injector pump to opperate as in when you swith off the ignition switch to shut down the engine.this is a serious fault and im not even going to adjudicate on it, because i consider it to be too dangerous a fault for suposition of what is actually rong with this vehicle ..it shuld be taken back to the dealer immediatlly and not taken on a public road until this serious problem is professionally repaired..s
#10 jeff_leopard
jeff_leopard
    Newbie
  • 7 posts
Posted 02 October 2010 - 09:25 AM
I had this problem on my Mondeo (2.0L TDCI 2004) - it would drive fine, then cut out with no warning. It would always restart without any problems. I changed the cam sensor with no change, and took it back to the dealer.
He changed the IMV and the car has been perfect every since!
