Leaky Cluch slave
4 replies to this topic
#1 Morbidos
Morbidos
    I would rather push a Mondeo than drive a passat
  • Lifetime Ad-Free Membership
  • 1,031 posts
  • Vehicle Driven:02' Mondeo 2l petrol
Posted 27 September 2010 - 08:36 PM
Just a little heads up about an error I'we found on two 2.0l Diesel kuga's... 09 Model. dont knwo if it's just these 2 cars but it's woth checking when you check the oil or refill the washer fluid once in a while...
Leaks brake fluid from the splice between the upper plastic bit and the slave sylinder/Cluch sylinder inside the gearbox... if you find this in ur car the gearbox has to come out and the slave has to be changed, tis is all coverd by warranty, if you cach this early on then the cluch and flywheel don't have to be changed, but drive to long with it and the cluch plate will disintegrate (this is usually how the costumer notices the fault)
open bonnet
shine a light between the airfilter box and the engine like so:
if you see this u need to go to ford and book it in:
this is where it comes from:
** X Ford Mechanic**
"02 Mondeo Mk3 2L Estate"Panther Black"Mk3 Diary
"94 Mondeo MK1 2L Estate"Ash Black"Mk1 Diary
#2 Morbidos
Morbidos
  • 1,031 posts
Posted 14 November 2010 - 11:16 PM
also had this on one S-max 09 and a Focus 09 now...
#3 barrie m
barrie m
    TF regular
  • 1,373 posts
  • Vehicle Driven:mondeo
Posted 16 November 2010 - 07:12 PM
had to do 1 on a 60plate 2.0 t/diesel galaxy with 1100miles
sounds like might b a fault on these
#4 Morbidos
Morbidos
  • 1,031 posts
Posted 16 November 2010 - 09:03 PM
the cluch sylinders ar the same that has been used on fords for years but seems like the quality standards have been lowerd....:s
#5 barrie m
barrie m
    TF regular
  • 1,373 posts
Posted 16 November 2010 - 09:13 PM
sounds about right
