Engine Replacement 1.7 Puma
2 replies to this topic
#1 L11XXY
L11XXY
  • 2,968 posts
  • Vehicle Driven:ST220
Posted 12 February 2011 - 02:40 PM
I've just bought a 99 1.7 Puma that suffered from an engine problem.
The guy drove it 20 miles without water in it (the valve to the heater on the bulkhead had split) The car got 1/4 mile from our house and stopped dead.
Compression was ok on 1 & 4 , 2 & 3 showed nothing and were full of water when the head was removed.
Therefore, do i source a second hand engine or will just a headgasket sort it out do you reckon?
What is the percentage chance that the head is cracked?
Advice would be helpful....
Alex
02 ST220,Retro Fitted Touchscreen Nav,Bluetooth, Voice Control,Climate Seats, OEM DVD Entertainment, RSE System, Xenons, Focus Sub Lighting
Live in Worcestershire, Herefordshire, West Midlands (South)or Gloucestershire and need IDS programming or diagnostics? KEY PROGRAMMING (PATS for cars up to 2001.PT for more info. Other areas may be considered Cheaper rates than your Dealer
#2 EVERTON2004
EVERTON2004
    Bloody Mondeo owners..
  • 2,649 posts
Posted 21 February 2011 - 12:13 AM
If there's no compression on two cylinders then it may well be piston and/or bore damage. Personally, I wouldn't risk fitting a HG to find out that the engine is fubar - I'd just throw in another lump (and if you're looking to throw an alternative lump such as a Zetec-E then this is the time to do it) :L
1999 Melina Blue Ford Cougar 2.0 Zetec 4x4
#3 Dal_ST
Dal_ST
    Forum Admin (Not here..lol)
  • 42 posts
  • Vehicle Driven:Mondeo ST TDci
Posted 09 March 2011 - 04:23 PM
if the cylinders are damaged, then the nikasil linings will be shot so it's a replacement engine I'm afraid.
If you've a 1.7, then you can't just throw in another lump without changing the ecu and wiring as only the 1.7 has Variable Cam Timing.
ST TDCi in Performance Blue so it's not mistaken for anything else. :}
Lovely 8 way Recaros,Sat Nav-ness,Park assist,Decat something or other, blah blah blah.
For sale >here<
