Noisy Timing Chain
3 replies to this topic
#1 PaulTDCi
PaulTDCi
  • 17 posts
  • Vehicle Driven:03 Mondeo TDCi 115
Posted 27 February 2011 - 03:34 PM
Hi, I have an 03 Mondeo 2.0 TDCi 115bhp. The timing chain sounds very loud, sounds like an old jeep!
Just wondering would spraying WD40 on it help or hinder the problem?
#2 Mabok01
Mabok01
  • 3,003 posts
  • 258 thanks
  • Vehicle Driven:Mondeo TDCI 130 2004
  • Name:Michael
Posted 27 February 2011 - 05:00 PM
No.
Don't spray WD40 on it. The chain is I believe lubricated with engine oil. If it is excessively noisy have it checked for tension and wear.
2004 Hatchback 130 TDCI Inkblue Mileage 443.000 Miles.
Genuine Ford fuel pump sprocket locking tool and pump mounting bolt tool for rent. Refundable deposit by Paypal required.
#3 salta
salta
  • 5,449 posts
  • 361 thanks
Posted 27 February 2011 - 05:25 PM
Hi Paul ..spraying wd on a timing chain is like putting pepper on chilli sauce ..not a goot idea.theres no easy way but you will find if you keep a good regular interval oil changed using the recomended formuls f oil for mondeo diesels it will make for a quieter chain ..but if the engine has been well worked in its life time so far then it would probably need a chain or at least a new tensioner and guides which im fairly sure can be ordered seperate from frauds but as for spraying anyting on the chain it would be a waste of time as soon as the engine starts the chain is lubricated with sump oil and anything like wd would be washed into the sump and would help to degrade the sump oil quicker..s
#4 PaulTDCi
PaulTDCi
  • 17 posts
Posted 27 February 2011 - 10:59 PM
Thanks for your help guys!!
