Recent Topics
Knocking Sound From Rear When Going Over BumpsPodzak - Today, 09:05 PM
Wiring ProblemPodzak - Today, 08:58 PM
Coolant Leak Mk2 2.0 BlacktopSquirt - Today, 08:45 PM
Rear Arm Rest Cupholderpeebee - Today, 08:43 PM
Steering RackUnder The Gun - Today, 07:46 PM
Mondeo Dab To Blaupunkt Sat Nav Help NeededMegansbob - Today, 07:16 PM
Brake Pipes Separate From Rear?Baz100 - Today, 05:40 PM
Dimming Rear View MirrorCurlyben - Today, 05:28 PM
07 Plate Auto To Manual Conversionamh01 - Today, 04:53 PM
Remapped Todaymr zefect - Today, 04:23 PM
Error codes - p2291 / p0251
Started by
dreaddan
, Mar 17 2011 09:31 AM
22 replies to this topic
#1
Posted 17 March 2011 - 09:31 AM
I've got my code reader today and have read the DTC's that point to the Inlet Metering Valve that needs replacing,
So can any one tell me where it is/how to replace it as I cant find it in haynes so I can check the contacts.
Also I think I read that it needs to be coded to the ECU is that right?
The codes were
p2291 injector control pressure too low - engine cranking
p0251 injector pump fual metering control a
Cheers
Dan
The codes were
Cheers
Dan
02 Mondeo TDCI Ghia x in Panther Black.
#2
Posted 17 March 2011 - 10:22 AM
when was the fuel filter last done how many miles ago?
#3
Posted 17 March 2011 - 11:20 AM
It was last done on tursday(a week ago) so about 400 miles. I requested a bosh one to be put on during the service it had.
#4
Posted 17 March 2011 - 02:33 PM
The imv is on the end of the pump under the inlet manifold. It has a brown electrical connection and should be next to the fuel temp sensor which is blue. That's if its a tdci 130. Hope that helps
#5
Posted 17 March 2011 - 08:22 PM
The codes were
Cheers
Dan
The codes were
Cheers
Dan
Its usually pump or injectors causing it.
#6
Posted 18 March 2011 - 11:23 AM
Im going to try to make it do it again while I have the lappie and cable in the car this weekend so hopefully I'll get more info before i replace anything.
but given i get abit of blue smoke at start up I feel it might be a injector.
#7
Posted 18 March 2011 - 02:39 PM
has it happened since it was changed or before? it could be a faulty filter even if it is bosch
#8
Posted 18 March 2011 - 03:10 PM
Both.
It happend a few times before and once again since
#9
Posted 18 March 2011 - 07:57 PM
its probably not the filter then.
seems an odd one to me i thought the fuel filter may have sorted it. how is the car actually running though? is it ok, smoking etc?
#10
Posted 18 March 2011 - 09:43 PM
Had a leak back test done today and one injector is leaking back considerably more than the others especially at higher revs which would cause a drop in pressure in the rail. Hopefully i have found my problem.
#11
Posted 18 March 2011 - 10:48 PM
Slightly more tappie than I can remmber but I've not been listning out until recentlly.
everything else seems fine. Better really got 47mpg from the last tank where I usally get 43ish
#12
Posted 18 March 2011 - 11:07 PM
You may have a faulty injector or two leaking off excessively and causing your low fuel pressure rather than the imv being faulty. Best do a leakoff test before shelling out on parts.
2004 Hatchback 130 TDCI Inkblue Mileage 404.000 Miles.
Genuine Ford fuel pump sprocket locking tool and pump mounting bolt tool for rent. Refundable deposit by Paypal required.
http://www.fordwiki....compatibility��
http://www.fordwiki....gory:Mondeo_Mk3
#13
Posted 19 March 2011 - 11:11 AM
it may be the case you will need to leave it for a while until it gets worse then. sometimes problems like this can only be solved by waiting for them to get worse unfortunately
#14
Posted 20 March 2011 - 04:33 PM
Well just to confuse matters I now have another code...
P1211 - Injector Control Pressure Sensor Above / Below Desired (engine running)
along with he p0251 again.
I had to retstart a few time on the m1 as the engine cut out after accelerating from 50 to 70 in 5th (dam roadworks).
So I guess thats the pump/metering valve then
#15
Posted 20 March 2011 - 07:02 PM
nope If you have an injector leaking back to much fuel (Even 1 on its own) it can still give Pressure fault codes
Mondeo MK3 TDCI 2002, Bluefin,De-Cat,EGR Blanked,K&N
#16
Posted 20 March 2011 - 07:32 PM
agree with the above think of it like this if its leaking too much there will be less pressure there. might be worth doing aleak off test
#17
Posted 20 March 2011 - 07:51 PM
also the is only 1 pressure sensor on the end of the common rail. if one injector drops pressure by leaking back to much fuel. then the sensor will still read the whole rail meaning fault codes related to pressure!
#18
Posted 22 March 2011 - 11:55 AM
Well I guess I need to find a delphi agent ...
#19
Posted 13 June 2011 - 07:41 PM
Looks like it's got worse
I now have the code P2339 cylinder 4 above knock threshold.
I guess I better get it booked in asap, I dout it'll make it to london next week
#20
Posted 13 June 2011 - 07:54 PM
being an 02 plate I would check the pump is not breaking up before laying out money on injectors
