Hesitation on Acceleration
18 replies to this topic
#1 Adam capri
Adam capri
  • 8 posts
  • Vehicle Driven:2002 Mondeo 115 TDCi
  • Name:Adam Keenaghan
Posted 01 April 2011 - 09:13 PM
Hi all,
I am new to this, so bear with me.
I have a problem with a 51 plate 2.0 TDCI Mondeo. Driving home i noticed that there was no acceleration when pressing the accelerator. This hesistation only last a second or two, but it is still worrying!!! Can anyone out there help me in any way???? Thanking ye for reading,
Adam
I WANT A CAPRI
#2 Hunta
Hunta
    Advanced Member
  • 40 posts
  • Vehicle Driven:Mondeo 2.0 (130) 02
  • Name:Chris Hunt
Posted 02 April 2011 - 12:57 PM
Hi all,
Adam
alright made i was experiencing the same problem and it turned out to be a split rubber hose going from the egr to the intercooler...have a look
#3 Adam capri
Adam capri
  • 8 posts
Posted 05 April 2011 - 08:06 PM
Hi Hunta, just looked at engine....... where abouts is that pipe your talking about????
I WANT A CAPRI
#4 Fordguy
Fordguy
    Apprentice mechanic
  • 275 posts
  • 16 thanks
  • Vehicle Driven:Ford Mondeo TDCI 130
  • Name:brian m
Posted 05 April 2011 - 08:10 PM
its the pipe that is connected to the bottom of the egr valve (left hand front of engine) and it goes to the intercooler. take a good look at the pipe as the slit is sometimes only 10mm long look out for oil patchs on the pipe this should help locate the split :L
the only way to get stubborn bolts off........................get thick with it
the only way to get stubborn ball joints to pop............................hit the fcuking thing..............its no relation
#5 totalguy
totalguy
    TDDI Buff
  • 37,014 posts
  • 388 thanks
  • Vehicle Driven:mondeo tddi
Posted 05 April 2011 - 08:22 PM
considering he has a 51 plate it may have a rear egr?
have a look in the guide to tdci thread there is a picture of a later tdci with front egr if yours is not here it will be rear right of the engine under the turbo
#6 Fordguy
Fordguy
    Apprentice mechanic
  • 275 posts
  • 16 thanks
  • Name:brian m
Posted 05 April 2011 - 08:25 PM
my bad only read the tdci oops :crazy:
Thanked by 1 Member:
Adam capri
#7 Adam capri
Adam capri
  • 8 posts
Posted 22 April 2011 - 02:25 PM
sound lads, thanks for the advice!!! However i now have another problem with a flashing glow plug light!!! I have read some of the advice on this site and i have changed the fuel filter, but to no avail!!! Any advice or hints???
I WANT A CAPRI
#8 Mabok01
Mabok01
  • Gold Member
  • 2,987 posts
  • 257 thanks
  • Vehicle Driven:Mondeo TDCI 130 2004
  • Name:Michael
Posted 22 April 2011 - 04:05 PM
Have you checked the popes yet. A badly split pipe could also cause the glowplug light.
2004 Hatchback 130 TDCI Inkblue Mileage 427.000 Miles.
Genuine Ford fuel pump sprocket locking tool and pump mounting bolt tool for rent. Refundable deposit by Paypal required.
#9 Adam capri
Adam capri
  • 8 posts
Posted 22 April 2011 - 04:14 PM
i checked the pipes, but i will have another good look now that you mentioned that!!!! anything i can check while i'm under there to help find the cause???
I WANT A CAPRI
#10 Mabok01
Mabok01
  • Gold Member
  • 2,987 posts
  • 257 thanks
  • Name:Michael
Posted 22 April 2011 - 05:29 PM
If you take the pipe off you may be able to see if it's split a bit easier. It isn't too hard to remove.
