Cabin filter changed my findings
10 replies to this topic
#1 Thadd
Thadd
  • 16 posts
Posted 18 April 2011 - 11:02 AM
Ive changed my cabin filter on my RHD mondeo mk4 using these instructions it was easy enough.
I bought my mondeo second hand with 18,000 on the clock and serviced twice, so I doubt it has had its cabin filter changes because I think ETIS says it wont need changed until its third service.
From the moment I bought it the air con was never that cold, the fans didnt blow that fast, it took ages for warm air to come through the vents, and after using the air con I got a musty smell from the vents.
It now has 44,000 on the clock and been serviced twice (not by ford). I never asked for the cabin filter to be changed.
I was able to easily change my mondeo mk3 cabin filter so I wanted to give my mk4 a go. The filter I removed was covered in what looked like black tar. The side with the black carbon looked nearly brand new
RESULTS!
The Fan Speed: What a difference, with the fan on full and vents pointing at me I find it hard to breathe its so much stronger. Reminds me of my mk3.
The Heat: I dont know how but it seems to heat up the quicker. I never got any warm air coming through the vents until the temperature needle was above 60 and that didnt happen for 20 minutes. I get warm air coming through after 5 minutes even though the temp needle hasnt moved.
The Air Con: The biggest improvement, my air con just didnt seem as cold as my mk3. Now its so so much better, on par with the mk3 I would say.
BTW this is with manual temperature controls
#2 tellmah
tellmah
  • 1,791 posts
  • 71 thanks
  • Vehicle Driven:Mondeo 2.5T Tit X
  • Name:Martin
Posted 18 April 2011 - 11:41 AM
RESULTS!
On ETIS for my MK4, it says to change the oudor filter (as they call it) every service.
:tonofbricks:
Mondeo 2.5T Tit X 2008, in panther black, sportspack and privacy glass. Never seem another model like it in my area. Looks good but getting naffed off with irritating faults and bad customer service..
Ford Escort, Morris Marina, Ford Granada, VX Astra Est, VX Cavalier x2, Rover 820, MK2 Mondeo
#3 Myfanwy Hertz
Myfanwy Hertz
    Monsieur Kev
  • 390 posts
  • 7 thanks
  • Vehicle Driven:2.0 Tit X
  • Name:Monsieur Kev
Posted 20 May 2011 - 07:15 AM
I have noticed that my air con is not comparable to my last two MK3's and I have had the pollen filter changed twice.
MIne is L/H/D which means the accelerator pedal has to be removed. I will do the job yself when the car is due its next service. I will be effing furious if the tow different Ford dealers have charged me for changing the filter, only to find it hasn;t been done.
This is such a bad design fault to make this filter so difficult to change. Lazy mechanics will say they have done the job, but how can you check? FOrd should do better than this.
#4 chriscatt
chriscatt
  • 4,506 posts
  • 78 thanks
  • Vehicle Driven:2014 A3 Saloon
Posted 20 May 2011 - 08:43 AM
Hi, I repeat what I said before, all cars that have to be adapted from right hand drive to left, or visa versa, will have to have compromises with the design, depending, of course, with how they they were originally designed. It just can't be helped and the recent recall with the Citroen C3 Picasso illustrates the problem car designers have, nothing is perfect...
Chris
2013 Fiesta Titanium X       2014 A3 Saloon 1.4 TFSI S-Line
1.0L 100ps Ecoboost          Daytona Grey
Candy Blue.
#5 herrbohnen
herrbohnen
    grumpy old git
  • 1,415 posts
  • 49 thanks
  • Vehicle Driven:Mk4.5 zetec estate
Posted 25 May 2011 - 03:03 PM
After much ado and struggling I've just changed mine, I noticed the air coming into the cab was really slow and the a/c was rubbish. I thought I'll just try the filter
see if you can spot the difference:
https://picasaweb.go...668959977366626
#6 herrbohnen
herrbohnen
    grumpy old git
  • 1,415 posts
  • 49 thanks
#7 herrbohnen
herrbohnen
    grumpy old git
  • 1,415 posts
  • 49 thanks
Posted 25 May 2011 - 03:04 PM
#8 4titx
4titx
    Over Enthusiastic
  • Gold Member
  • 5,374 posts
  • 206 thanks
  • Vehicle Driven:Mondeo 4 Titx
  • Name:Phil
Posted 25 May 2011 - 03:11 PM
Oh you decided to put a white one in instead of a black one. Now that will only get dirty you know :whistling:
LEDs, whats your Watts.
#9 Alex Heney
Alex Heney
  • 168 posts
  • 6 thanks
  • Vehicle Driven:Mondeo Edge Estate
  • Name:Alex Heney
Posted 25 May 2011 - 03:36 PM
You replaced it three times in a minute?
Fast work :biggrin:
Mondeo Mk IV Edge Estate 2.0TDCi 140
Silver-grey, no modifications
Registered August 2007, bought 2nd hand April 2011 with 92K on the clock
#10 herrbohnen
herrbohnen
    grumpy old git
  • 1,415 posts
  • 49 thanks
Posted 26 May 2011 - 02:12 PM
i dont know what happened there
