Recent Topics
Mondeo poor MPG
17 replies to this topic
#1 Duratec-Tom
Duratec-Tom
  • 11 posts
  • Vehicle Driven:Mondeo
Posted 03 May 2011 - 12:48 PM
Hi All,
I'm new to the site and this is my first topic. I have a 2004 Mondeo LX (Automatic) with 2.0litre petrol Duratec HE engine. I bought the car in August last year and did not realise, at the time, that the MPG is not what it should be. At best on a long motorway run I've had 26mpg and around town this drops down to 18. Also, since January the car has developed a intermittent judder when coasting to a junction and also when under heavy load (climbing a hill at speed). However, this does not happen all the time.
I have changed the plugs, oil (twice), lambda (oxygen) sensor, fuel filter, air filter and gear box oil all of which has not helped. We have also removed the EGR valve and given this a clean. Has anyone got any other ideas which I have not thought of as this engine is driving me mad! (hence the name). No fault codes have been thrown up by the engine management system which is not much help either. I suspect the T-MAP sensor which I have ordered a replacement for but am unsure if this could have such a dramatic effect on the fuel economy.
Any help/ideas would be gratefully received.
#2 andy ghia x
andy ghia x
  • 848 posts
  • 8 thanks
  • Vehicle Driven:ford mondeo mk3
Posted 03 May 2011 - 01:55 PM
View PostDuratec-Tom, on 03 May 2011 - 12:48 PM, said:
Hi All,
hi there
sounds like the coil pack is breaking down under load. does your obd2 code reader do 'live' data? if so, what is the long term fuel reading?
hth
OBD-II scans in Lanarkshire using Autel MS509 ,Just ask.
Ford Mondeo Ghia X 2003 2.0 16v petrol.
#3 Duratec-Tom
Duratec-Tom
  • 11 posts
Posted 03 May 2011 - 02:06 PM
Hi Andy,
Thanks for commenting. I have read that it could be the coil pack but discounted this as it happens when you are coming to a junction with no load on the engine. Could it still be the pack and would this effect the economy? Also, I don't think its misfiring. The reader shows that the calculated engine load is always around 35% and sits at 45% when the engine is just ticking over, this seems high. I have not looked for the long term fuel economy but will check and see if I can find this out.
#4 4x416v
4x416v
    Every angle has an apex!
  • Forum Moderator
  • 6,998 posts
  • 131 thanks
  • Vehicle Driven:Mondeo Mk3 Ghia X
Posted 03 May 2011 - 03:04 PM
Hi,
the judder is a missfire, this could be caused by the coil pack  / HT Leads (best to change this anyway try to find a similar car on ebay which is being broken and buy new leads) could well be that your maf is on it's way out, when a maf is going it will cause a missfire and drastically increase the fueling (runs rich) as a faulty maf increases fuel pressure to compensate for a lack of air  which it is not reading and hence over fueling.  Best way to make sure if your MAF is working or not is dissconnect it and drive the car around, if the car feels worse then you know its not the MAF, if it's no different the MAF will need replacing.
HTH
Mk1 Mondeo 2.0si 4x4
Mk3 Mondeo Final Facelift 2.0 Ghia X
My Mk1 4x4 diary:
http://www.talkford....80#entry1497480
What's next: Mk3 ST220 Final Facelift or Mk4 2.5T tit x
Talk to me about Winter / Summer tyres, wheels and chassis mods.
#5 Duratec-Tom
Duratec-Tom
  • 11 posts
Posted 03 May 2011 - 03:35 PM
View Post4x416v, on 03 May 2011 - 03:04 PM, said:
Hi,
HTH
Thanks for this, I will have a look for the coil pack. I looked for the MAF sensor as well but the duratec petrol engine doesn't have one. It uses a T-MAP sensor positioned in the inlet manifold. When I removed this it was covered with grime so I think this is worth replacing and have ordered a new one from Ford (£46.01). I can't help but think that the rubbish economy and judder are linked even though the judder started 3 months after I bought the car which has had the poor economy since I bought it.
#6 4x416v
4x416v
  • Forum Moderator
  • 6,998 posts
  • 131 thanks
Posted 03 May 2011 - 03:42 PM
yes the missing and fuel economy are probably linked.  My Mk3 2.0 Duratec HE averages 33 MPG combined cycle, so it sounds like your's is overfueling.
My Mk1 4x4 diary:
#7 Duratec-Tom
Duratec-Tom
  • 11 posts
Posted 11 May 2011 - 12:33 PM
Just an update on the issue, replaced the T-MAP sensor and this has helped on long distance journeys MPG climbs rapidly to mid 30's however around town it still nose dives back to 22-23 mpg. I don't think this is right. Does this still point to the coil pack, I think it does. Also does anyone know where I can check the fuel pressure? There is supposed to be a valve close to the injectors in the engine however I cannot find this. Would it be in a different place for an auto?
Also, do you think it makes any difference if I bought a coil pack, and leads, that weren't Ford? I have read that a damaged coil pack can also damage the ECU and cause issues when you replace it. Is this true?
#8 stripe88
stripe88
  • 1,749 posts
  • 127 thanks
  • Vehicle Driven:mondeo 2l ghiax
Posted 11 May 2011 - 01:21 PM
the test port is the bit under the blue cap here (duratec HE)
if you dont release the pressure first use plenty of rags when you put the Gauge on/off,  a standard tyre gauge will do.
4 cylinder 1.8 2.0 380 kPa (3.8 bar 55 Psi) +/- 5% at idle and greater then 250 kPa (2.5 bar 37 Psi) after ten mins.
V6 2.5 450 kPa (4.5 bar 65 Psi) +/- 5% at idle and greater than 320 kPa (3.2 bar 46 Psi) after ten mins.
btw   whats your temperatures like on the dash display and  temp gauge, maby running rich/lean
#9 Duratec-Tom
Duratec-Tom
  • 11 posts
Posted 11 May 2011 - 01:53 PM
Hi, great picture thanks for this. My car does not have this valve! Do you think it could be somewhere else as I assume there must be one. 53 plate auto (2.0l).
Temperature gauge never goes above the midway point although code reader shows coolant temp as high as 220f when driving. I assume that this is normal as these engines do run hot?
#10 bumdump1
bumdump1
    GTR Manchester Meet Organiser
  • 1,724 posts
  • 93 thanks
  • Name:Matt
Posted 11 May 2011 - 02:01 PM
I have 2.0 auto as well, my mpg is around 29 around town  Info says 26 - i dont do much motorway so i've never worked it out.
Auto's do use more over manuals!
Ford Mondeo Mk3 Estate Automatic in Oyster Silver - Modified and Upgraded
Common faults and guides for most Fords can be found in the:-  TalkFord Wiki Guide
Ford Etis Online Technical Information:- Ford Etis
Greater Manchester Regional Group
Covering Stockport, Tameside, Oldham, Rochdale, Bury, Bolton, Wigan, Salford, Trafford
#11 Duratec-Tom
Duratec-Tom
  • 11 posts
Posted 11 May 2011 - 02:08 PM
Thanks for the response. I thought that it would be worse around town but this seems a bit much! Especially when you are getting 29.
#12 Lez
Lez
  • 8 posts
  • Name:Lez
Posted 13 May 2011 - 12:26 PM
Hi there,
Have a 2.0 auto also mine averages 24, had loads of ford autos cmax 2.0 auto averaged 22. During the cold winter mine went down to 18. Its a fat car with a dated auto box you will never get decent economy from it. I'd probably be more worried about the judder could well be the auto box a missfire usually throws up a fault code.
#13 Duratec-Tom
Duratec-Tom
  • 11 posts
Posted 23 May 2011 - 12:23 PM
Juast an update on my problem. Replaced the coil pack, as recommended, and this has solved the problem! Its a pleasure to drive again. I also reset the ECU as I had heard that this can cause issues with a new coil pack. Bought the part locally (not Ford) for £48 and leads for £22. So far no problems.
Thanks to all who gave advice.
#14 Duratec-Tom
Duratec-Tom
  • 11 posts
Posted 23 May 2011 - 12:24 PM
#15 marklx
marklx
  • 196 posts
Posted 03 July 2011 - 08:15 PM
Hi tom.Just purchased our 2000 ghia x auto and had the same problem as yourself.Was gonna fit the coil pack n leads off our written off mk1 but whilst away at our caravan I took each plug lead off the coil pack and pushed them back home.Guess it could have been a backed off lead or dislodged one whilst cleaning up around the bay. Thanks for your help to save the headache of replacing loads to find the prob,these forums are really great way of finding out that your not the only one with the only car in the uk to have the problems.Cheers all.our mondy7.JPG Before the clean up.
#16 CraigW
CraigW
  • 36 posts
Posted 04 September 2012 - 01:57 PM
@Tom, what mpg are you getting now? I average 35 if I drive like a nun. 'Normal' town driving gets more like 22.  Car has always been like that and seems smooth.
54 plate mk3 2.0 auto zetec.
#17 indexx
indexx
  • 2 posts
  • Vehicle Driven:Mondeo mk3
  • Name:Peter
Posted 13 September 2012 - 01:43 PM
Quote
Here:
~ 33mpg on motorway
~ 27mpg in normal "city" use
2.0 liter duratec, automatic. I think it can't make any better...
#18 shorey
shorey
  • 14 posts
Posted 15 September 2012 - 08:43 PM
Are the autos really that bad?
My manual does;
40mpg motorway only (ie long trip),
35mpg mixed and,
around 30 driving it like I stole it.
Seems a hell of a difference.
