Mondeo TDCI 130 EGR Valve - Blocking
17 replies to this topic
#1 Ross_130
Ross_130
    Newbie
  • 21 posts
Posted 23 May 2011 - 08:50 PM
Hi All,
Just wanted to know if any one has done this:
http://fordwiki.co.u...ocking_On_A_Mk3
And is it a safe option? If not how easy/hard is it to blank the EGR?
My mondeo is a 54 plate euro 3 i think :-/
162k
Thanks.
MK3 Mondeo TDCI GHIA
EcoBox Tuning Box
18'' Zetec-S alloys
#2 totalguy
totalguy
    TDDI Buff
  • 37,014 posts
  • 388 thanks
  • Vehicle Driven:mondeo tddi
Posted 23 May 2011 - 09:53 PM
that link is for a rear egr so different to yours but you could do that on yours. is there an electrical connector on your egr? if not you can do that or just remove the vac pipe.
if you dont know where your egr is look in the guide to tdci sticky theres a picture with labels
#3 the big yin
the big yin
  • 12 posts
  • 1 thanks
  • Vehicle Driven:Mondeo TDCI Zetec
Posted 24 May 2011 - 08:53 PM
Is it safe to do if there is an electrical connector on top (remove vac pipe)
#4 capri_rob
capri_rob
  • 57 posts
  • Vehicle Driven:03 Mondeo Zetec TDCi
Posted 25 May 2011 - 08:49 AM
If its got the electrical connector blocking the EGR will put the warning light on.
#5 salta
salta
  • 5,453 posts
  • 361 thanks
Posted 25 May 2011 - 01:17 PM
Hi All,
162k
Thanks.
Hi Ross ..you should first study exactly what the EGR valve does in you motor ..I t recycles the hot exhaust gas back to the inlet manifold ..which cause more nox. and reduces the temp or the explosion in the cylinder when it fires this cause a lower emission and reduces soot being expelled int the cath.converter and makes for cleaner emissions.......blankinig the egr has the effect of making the motor constantly use fresh oxygen and reduces the possibility of a faulty EGR .causing the engine to use more fuel and run inefficiently .Im not a proponent of the practise but plenty of guys on here swear by the practise for more economy and power .....But using a ball-bearing is in my opinion not the way to go .firstly the ball-bearing may not block the vacume as its quite hefty vacume ..and secondly when a ball-bearing is inserted there is no way unless you have xray vision of knowing that the valve is in the closed position .and wil stay like that ..as is the point of blocking the valve ..ther are cheap plates one can purchase on the internet which actually block the pipe at the join wherer it connects to the metal pipe going to the inlet and this is probably the best way the plate is slotted so all thats necessary it to loosen the two 8 bolts and slide the plate into postion thus blocking the pipe form the egr permanently and definitely ..the downside of doing this is a an engine warning light may be shown which can either be lived with of constantly erased using some software like Fsuper ..s
#6 salta
salta
  • 5,453 posts
  • 361 thanks
Posted 25 May 2011 - 01:21 PM
Hi All,
162k
Thanks.
#7 Ross_130
Ross_130
    Newbie
  • 21 posts
Posted 25 May 2011 - 07:41 PM
Hi All,
162k
Thanks.
I found out my car is a euro 4 with the electronic plug thats plugs beside the EGR.
I unplugged and what a difference! no engine management light came on i took it for a 30 min drive was fine ! seems allot better i must say!
EcoBox Tuning Box
18'' Zetec-S alloys
#8 SRH990
SRH990
  • 1,413 posts
  • 32 thanks
Posted 25 May 2011 - 09:57 PM
Hi All,
162k
Thanks.
The EML light will come on in a couple of days at most in my experience.
Steve H
'06 Zetec TDCi 130 Euro IV, '04 TDCi 130 Euro IV
#9 Ross_130
Ross_130
    Newbie
  • 21 posts
Posted 25 May 2011 - 10:14 PM
Hi All,
162k
Thanks.
Yeah the light came on when i was driving to the shop earlier :( .. but car feels better. Gunna clean the EGR this weekemd to see how dirty it is.
EcoBox Tuning Box
18'' Zetec-S alloys
#10 danwfastford
danwfastford
  • 2,172 posts
  • 58 thanks
  • Vehicle Driven:2.0 TDCi TiTX Estate
Posted 26 May 2011 - 08:34 AM
I'm not quite sure what you mean by this - It appears that you're suggesting that the EGR makes the car more fuel efficient? If that's the case, then that's not true. The EGR actually makes the engine LESS efficient, as it lowers temperature of the combustion process.
It you want clarification of what an EGR actually does, go here and scroll down to the bottom, where you'll find an informative article on Exhaust Gas Recirculation valves.
www.fastfordmag.co.uk
Try it, you might like it!
