Tappets Tappets Tappets
3 replies to this topic
#1 Hmanz
Hmanz
  • 1 posts
  • Vehicle Driven:Ka
  • Name:Hman
Posted 07 June 2011 - 03:22 PM
adjusted my tappets today (because Ka's are noisy and this happens quite alot!)
for those of you who are thinking of doing theirs:
Exhaust valves should be 0.5mm and inlets 0.2mm and are checked / adjusted cold.
Gasket is a cork item which usually breaks up when you move the cover. Even at a Ford dealer they're only a couple of quid, so you might as well replace it.
(and also the old one is a ball ache to remove. i suggest a small hammer n a flat head screwdriver or chisel to gently get off the old cork gasket!)
You just need a spanner for the rocker cover bolts, and another for the rocker arm bolts / adjusters, plus of course a good set of feeler gauges.
The rocker arm adjusters wind in against a spring which is supposed to eliminate the need for a locknut. Therefore, you just turn the bolt clockwise to reduce clearance, and anti-clockwise to increase it - there are no locknuts to worry about.
It's very simple and logical when you see it
hope anyone finds this helpful :) Hman
#2 MScotts
MScotts
    Never knowingly understood
  • Lifetime Gold Member
  • 23,164 posts
  • 20 thanks
  • Vehicle Driven:ST200 Saloon
Posted 08 June 2011 - 06:00 AM
I'm sure many will find it useful matey... :)
Now a sticky topic :L
4-wheels - LPG converted ST200 Saloon Ltd Ed No.177
2-wheels - BMW Motorrad and Honda HTM
Unfortunately Andy (MScotts) passed away suddenly on the 9th October 2013. RIP Andy, you'll be missed by all.
#3 etrebus
etrebus
  • 3 posts
  • Vehicle Driven:escort
Posted 29 July 2011 - 08:26 PM
also a good trick i learnt was if rockers are worn then you cant measure the clearence properly so to quieten them up you need to remove the rocker shaft and with some 400 wet and dry paper wrap it around a flat file and gently sand the rocker faces flat again then replace rockers and re adjust , i have done this many times and found it quietens them much more than just adjusting
#4 etrebus
etrebus
  • 3 posts
