Caliper diagram
2 replies to this topic
#1 Martynmnart
Martynmnart
  • 413 posts
  • 2 thanks
  • Vehicle Driven:Mondeo MK3 Ghia
Posted 04 July 2011 - 10:37 PM
Just wondering if anybody has or knows where I can get an exploded view diagram of a rear brake calliper (2005 mk3 tdci 130)
Iv recently changed the rear calipers for recon ones, the nearside worked fine but the offside handbrake mechanism didnt work correctly. I then took this back and swapped it for another with the same problem (both times the hydraulics worked perfect) the piston only moved about 2 or 3 millimetres when the lever was operated. I'm just curious as to how the handbrake mechanism works. Iv tried the google but it hasn't turned up what I'm looking for
Thanks Martyn
Stardust Silver 55 Plate MK3 Mondeo Ghia TDCi 130 6 speed
Mods: Blanked EGR, Auto folding mirrors, De-Cat pipe, Remap (redbitz sorted by Shaun) Aero wipers, Osram Nightbreakers, LED side lights, Interior LEDs and puddle light LEDs, FLI active sub (1000w), K&N 57i induction kit
#2 ST56
ST56
  • 495 posts
  • 35 thanks
  • Vehicle Driven:ST TDCi
Posted 05 July 2011 - 07:18 PM
Hi
The video on the attached link will give you a clue how these calipers work: http://www.myturbodi...ton-works-3962/
This is for a VW but ford units work in a similar war.
Peter
5 Door ST TDCi, Performance Blue, Privacy glass, Black Leather/Alcantara Recaro's, Denso Sat Nav,
Advanced Bluetooth, Voice Control, Rear Parking Sensors, Jaguar Flip Key, DiamondVision Main Beam,
CrystalVision Fog, Eibach Springs Fin No.1132335, Added Foam Rear Bumper support pads.
ASBO Calipers Painted Silver. Ford Discs Front & Rear. With RedStuff pads fitted Front and back.
CCFL Halo’s by Chromiumtech. 6000K D2S in Ford Projectors. FORGE Boost & Inlet Hoses.
Silencer tried to escape so replaced with a 4’’ slash cut backbox from MIJ Exhaust.
#3 totalguy
totalguy
    TDDI Buff
  • 37,014 posts
  • 388 thanks
  • Vehicle Driven:mondeo tddi
Posted 05 July 2011 - 07:35 PM
good video i didnt realise it worked like that but now i know :L
