Recent Topics
New Diesel FilterRekusu - May 23 2013 07:41 AM
Key Fob CodingAndy76 - May 22 2013 10:10 PM
Odd Light Problem...andyrev1 - May 22 2013 10:06 PM
Thanksjonyboyjonweechocbanana - May 22 2013 09:03 PM
"easy-Fill" Fuel Problemsandyrev1 - May 22 2013 09:01 PM
Catalytic Converter Faultsthegfb - May 22 2013 08:25 PM
St200 / Regular V6 Mondeo Ecu WiringsMikkoMuhis - May 22 2013 07:03 PM
Temp FixPURPLE_2L_LX - May 22 2013 06:27 PM
2.5T Running Out Of Patience!Marky68 - May 22 2013 06:09 PM
What They Worthstevegtuk - May 22 2013 05:46 PM
Wiring In a 12S Socket and split Relay
Started by
Yozza64
, Jul 14 2011 06:55 PM
7 replies to this topic
#1
Posted 14 July 2011 - 06:55 PM
Hi Guys, im going to be fitting a 12S (Grey) Socket and Split Relay to charge my caravan battery and run my fridge. Does anyone know how difficult it is to wire up
The main things I need to know what wires are hard wired to the car and also what wires are connected tot he split relay.
Any diagrams would be a big help. Or can anyone point me in the right direction to any links
Thanks in advance
Thanks in advance
MK3 2004 FORD MONDEO 1.8 LX 123BHP in Stardust Silver. At moment completely standard. No plans for any mods
TO DO LIST : Full Service.
#2
Posted 15 July 2011 - 02:42 AM
Get a smart relay, Cuts power automatically if the voltage is too low. No need to mess.
One heavy duty wire from the battery directly to the rear socket with an inline fuse. Earth and sorted. Well almost.
2004 TDCi 130 LX Estate. (6)
#3
Posted 15 July 2011 - 11:53 AM
What else would I need to do. Also ive been told that i need a switched live from the ignition as well
#4
Posted 15 July 2011 - 08:05 PM
Anyone else
#5
Posted 16 July 2011 - 12:54 AM
No the smart relay detects the battery voltage and switches the power on and off automatically.
A much easier option compared to the old system where you need a relay switched from the ignition. You had to be careful
on that sometimes, If the car battery was low it could try and draw power from the caravan battery.
#6
Posted 20 February 2012 - 05:50 PM
power feed off the battery via fuse to smart relay in. feed out to 12 s socket or 13 pin for the fridge and battery system. ensure that you have a good earth for the smart relay.
2001 mk3 tddi.So far on mods..footwell lights, etac pannel ,burry handsfree,nightbreakers.t o do mudflaps and rust issuses. Died 13-6-11 rip
2006 mk3 tdci 'back to life car'' climate, powerfolds, twin bootlight, leather stering wheel and handbrake .
#7
Posted 21 February 2012 - 11:53 AM
? Time warp? July last year
#8
Posted 25 February 2012 - 05:46 PM
Assume you are only interested in the Mondeo? Understand on the later cars (and certainly the S-Max) the wiring has to be recognised by the ECU computer brain or it chucks it out? - looks like a trip to the Ford Dealer?
Dont know if its the same on the Mondeo
pete
pete
