Fuel filter replacement problem
23 replies to this topic
#1 danzz41
danzz41
  • 13 posts
  • Vehicle Driven:Mondeo mk4 2.0 TDCi
  • Name:Martin Janda
Posted 16 August 2011 - 06:26 PM
Hi,
I´ve just tried to replace fuel filter paper element on my mondeo 2.0 TDCi but with no success. The problem was when I was emptying the fuel filter by draining bolt at the bottom of filter, diesel hadn´t stop flowing from it. I was expecting a half of litre of diesel or something but it was much more. When I got 2 litres of diesel i stopped it assuming I was doing something wrong. Do I need to disconnect some pipe from tank or the electric connector plugged into the filter? Any advice would be appreciated.
Thanks, Martin
#2 JasonH
JasonH
  • 56 posts
  • 5 thanks
  • Vehicle Driven:Mondeo 2.0 TDCi Mk4
  • Name:Jason
Posted 16 August 2011 - 08:47 PM
I had exactly the same problem. I was using a 2 litre plastic milk carton to collect the diesel. I filled it 3 times!!!! I had to empty it into my other car because that had a normal filler neck (carefully only pouring the clean diesel in I might add).
As there was no way the filter could hold 6 litres (2 maybe) I cautiously undid the filter housing with the drain open. That broke the vacuum that was causing the syphoning and the diesel stopped coming out.
After that hiccup I had a bit of a result bleeding the system. I made the contraption pictured here and used a vacuum cleaner. It bled the system perfectly in about 20 seconds without getting any diesel in my vacuum cleaner. The vacuum even held the hose onto the jam jar!
  • herrbohnen likes this
#3 silverzetec
silverzetec
  • 25 posts
  • 1 thanks
  • Vehicle Driven:mondeo 2011
Posted 17 August 2011 - 08:41 PM
Thats a fantastic system.Wish i had seen that last week.
#4 danzz41
danzz41
  • 13 posts
  • Name:Martin Janda
Posted 18 August 2011 - 06:45 AM
Jason, your bleeding stuff is just brilliant :)
after all I took my car to a Ford dealer to change the filter for me. Then I asked the mechanic for some tips on how to do it and he told me this:
1. disconnect two pipes and electrical connector
2. plug pipes to prevent aeration of fuel system
3. drain diesel from filter housing using the drain bolt (aprox. 1 litre)
4. unmount the whole filter, replace paper element
5. fill the filter with diesel as much as possible
6. mount the filter to its holder, connect both pipes and connector
That was it, bleeding wasn´t necessary. But if it was I made bleeding pump from a hose of bike pump connected to this http://www.akcni-nar...adickami-yt0707, it´s one-way oil pump (cost me £12) and together work great.
So I hope next time after 40.000 km I´ll make it by myself :)
#5 herrbohnen
herrbohnen
    grumpy old git
  • 1,409 posts
  • 49 thanks
  • Vehicle Driven:Mk4.5 zetec estate
Posted 19 August 2011 - 07:06 AM
you should be on TV with ideas like that !
#6 JasonH
JasonH
  • 56 posts
  • 5 thanks
  • Name:Jason
Posted 19 August 2011 - 08:02 PM
Blimey that's a hard way.
1. I loosened the drain nut, drained the filter.
2. Unscrewed the filter cap.
3. Replaced the filter and gasket put the cap back on.
That's the filter replaced, now the bleeding
4. Screw the shraeder valve of the bike pump attachment of the contraption above to the fuel bleed valve
5. Use the vacuum cleaner to pull the air and diesel through until no more bubbles
Could do it in 20 mins now I know how.
#7 maximumx4
maximumx4
  • 1 posts
  • Vehicle Driven:mk4 mondeo
  • Name:simon
Posted 08 October 2011 - 03:19 PM
Just prchased Mk 4 mondeo 2.0 tcdi went to replace fuel filter and its gone!
Cant find it any where? Where did they put it .. Thanks
The Info on the Pollen filter was great better to take out glove box though!
#8 JasonH
JasonH
  • 56 posts
  • 5 thanks
  • Name:Jason
Posted 09 October 2011 - 01:51 PM
Diesel filter on the 2.0 is between the rear wheels under the car - you can just about access it without jacking the car up.
#9 SJJ
SJJ
    Newbie
  • 1 posts
Posted 28 March 2012 - 06:11 AM
Hi
First of all sorry to drag up an old thread.
When you connect the shraeder valve to the bike pump attachment do you remove the centre from the valve.
Mine went in yesterday for a fuel filter change and it now wont start.
Many thanks
Steve
#10 herrbohnen
herrbohnen
    grumpy old git
  • 1,409 posts
  • 49 thanks
Posted 29 March 2012 - 06:31 PM
No , the bike pump pipe pushes on the valve centre and allows flow , otherwise you would never be able to take the pipe back off
