Display Error
No replies to this topic
#1 Golfers Choice
Golfers Choice
  • 2 posts
  • Vehicle Driven:Ford Fusion
  • Name:Ivie Davies
Posted 18 August 2011 - 08:43 PM
I have a Ford Fusion and the disply shows "Boot Open" even though the boot was closed. On inspection a plastic block close to the latch was loose and I assume that this is the switch. I put a cable tie around this to keep it closed and the system now works OK, other than if the boot was open there would be no warning.
Does anyone know how this switch can be replaced and can a switch be purchased as a seprate item?
