Recent Topics
Cutting OutRavmann - Today, 03:43 PM
Top Tether Anchor Point, Car Seatcosteau - Today, 03:10 PM
Cigar Lightercyril - Today, 02:37 PM
Loom Connector For Headlamp Washer?FITZYNKAZ - Today, 01:53 PM
Iphone Radio Unitmaster chief - Today, 01:51 PM
Mk3 Calipers On A Mk2 With Turbinesbbb - Today, 01:08 PM
Tdci Flashing Glow Plug Under Load And Now Car Wont StartMarkostarletturbo - Today, 12:47 PM
Fuel Filler Problem.betterman0112 - Today, 12:10 PM
Radio CodeMarkostarletturbo - Today, 11:56 AM
Aux Plug In GloveboxJust - Today, 11:39 AM
Mega fuse 175A
Started by
takee
, Aug 20 2011 12:21 PM
8 replies to this topic
#1
Posted 20 August 2011 - 12:21 PM
Does anyone happen to know where the mega fuse is located on a V6 mondeo? It is the main power fuse between the alternator and the battery.
On the USA versions (Contour, Mistique) it is behind the coil pack, just in front of the firewall, bolted onto the main cable harness case (right next to the lambda sensor's connector), just under the ignition distributor.
I disassembled the whole area to get to the alternator's plugs, but there is no mega fuse box. Did anyone ever saw it somewhere?
V6 Ghia converted to ST200
Sunroof installed in OEM quality. There is no such thing as impossible...
#2
Posted 20 August 2011 - 12:28 PM
as far as i know there is not one, all the fuses are here in the wiki
http://www.fordwiki....lay_information
#4
Posted 20 August 2011 - 01:07 PM
Interesting, Contours definetely have one!
#5
Posted 20 August 2011 - 01:12 PM
according to philmons link it appears to be mk3 mondys with this and cougars. in the uk it seems as though its only there if the motor is from brazil, interesting read, and am unsure why you'd need a 175a fuse... don't think the alternator is capable of creating that sort of power...?
#6
Posted 20 August 2011 - 01:20 PM
philmon, on 20 August 2011 - 12:33 PM, said:
Read this mate, http://www.talkford....-fuse-in-st220/
Yepp, I thought so, this is a US spec. fuse. Then, I have nothing to worry about.
Thanks.
#7
Posted 20 August 2011 - 02:09 PM
The only UK Fords I've come across that use this fuse between the alternator and the battery are the Maverick 4 & 6 cylinder (this is a 120 amp fuse) Cougar 4 & 6 cylinder(175amp) ST220 (175 Amp) Mk2 Galaxy 4 & 6 cylinder (150 Amp) Focus C max all engines (150 Amp) and transits use fusible links but I'm not sure what they are rated at.
Steve
Steve
Current Mondeos are:
53 Ink Blue ST220 estate
97 Panther black 2.5 ghia X saloon
And my other toys are:
1994 Ford Escort RS2000 4x4
1987 Ford Capri 2.8i special
1998 Ford KA2 & 1998 KA3
#8
Posted 21 August 2011 - 07:10 PM
The red one is what I am talkin' about (pic taken in a Contour's engine bay).
View Garage
