Rear Wiper not working
8 replies to this topic
#1 ninesheds
ninesheds
  • 2 posts
  • Vehicle Driven:mondeo
Posted 21 October 2011 - 10:43 AM
Hi All,I have a Mondeo 2002 TDCI my rear wiper has stopped working,where do i start? do i replace the rear wiper relay first?would it be the motor and where is it?also there isnt any water coming through when i press the wash button as well but i can hear the pump?going ,the front wipers and washers work perfectly well.
i would be grateful for any help.
#2 siruncle
  • Regional Moderator
  • 16,105 posts
  • 983 thanks
Posted 21 October 2011 - 01:40 PM
wiper motor is inside the tailgate behind the big plastic trim, before taking all the screws out check the fuses and relays, (click fordwiki at the top then choose mondeo, mk3 for fuse and relay info)
as for the rear washer, it could be the pump pump filter is full of crud, if they're anything like other ford ones they just pull out the washer reservoir, you may need to remove some underbody/wheelarch trim to access them, in the bottom of the washer tank.
2000 (W) Mondeo Mk2 Ghia 2.0 Hatch in Stardust Silver, now needing a pair of front jacking point covers... msg me
Thanked by 1 Member:
ninesheds
#3 ninesheds
ninesheds
  • 2 posts
Posted 21 October 2011 - 08:45 PM
Thanks very much for your help siruncle very useful i will sort this tomorrow
#4 siruncle
  • 16,105 posts
  • 983 thanks
Posted 21 October 2011 - 11:06 PM
np mate, hopefully will find the problem and be able to sort it, best of luck.
#5 PURPLE_2L_LX
PURPLE_2L_LX
    Mondeo Mk3 Moderator
  • 16,280 posts
  • 763 thanks
Posted 21 October 2011 - 11:16 PM
Unplug the motor wiring and connect it directly to a battery and see if it moves.
Link to fuse info below if you dont have one handy.
2004 TDCi 130 LX Estate. (6)
ninesheds
#6 houdi
houdi
  • 13 posts
  • Vehicle Driven:ford mondeo tdci
  • Name:martin yeeles
Posted 25 October 2011 - 06:25 PM
not sure about the rear wipers not working but for no water coming out it could be the pipe has come away (common fault so ford told me) its situated in one side of the plastic covering above the back seat so i was told by ford,i have the same problem no water coming out not had time to check mine yet
#7 PURPLE_2L_LX
PURPLE_2L_LX
  • 16,280 posts
  • 763 thanks
Posted 26 October 2011 - 03:50 PM
As mentioned the other issues are the pipe coming apart around roof area in the C pillar. Or the actual washer jet nozzle is clogged.
1st pop the pipe off the rear nozzle and see if any water comes out. If yes its the blocked nozzle, If not check the roof area by the C pillar
wet? Failing that swap the pump.
The pumps can still whirr away but not actually pump any water. Check it the small plastic filter over the pump
inlet. This clogs and starves the pump of water and burns itself out.
Did that to my old car, It would squirt a bit then stop, Eventually it burnt out because i kept pressing the washer button.
New motor sorted the problem out.
Not sure if i refitted the filter or not?
One pump works the front and rear washers, I presume it spins opposite directions, You could try swapping the pipes over.
See if the front stops working and the rear starts working.
#8 chumba1980
chumba1980
  • 1 posts
Posted 25 June 2014 - 05:20 AM
Hello all my rear wiper is not working I can here the replay click in car but no action on wiper 2006 titanium estate how do I get to motor?
#9 FiatluX
FiatluX
  • 3 posts
  • Vehicle Driven:Mondeo Mk3 Estate
  • Name:BSL
Posted 28 June 2014 - 10:11 PM
2 screws in the doorhandles and the tailgate inner cover pulls away with gentle force!
Edited by FiatluX, 28 June 2014 - 10:11 PM.
Mondeo Mk3 Estate 06/2005 Series 60 Titty X, 2.0 HE SEFI, Stardust Silver
