how do i do a leak off test
21 replies to this topic
#1 animal1978
animal1978
    02 tdci 130 ps euro 3
  • 195 posts
  • 11 thanks
  • Vehicle Driven:02 tdci
  • Name:carl
Posted 03 November 2011 - 10:20 PM
hi does anyone know how to do a leak off test? want to see tomorrow if this is the problem with my mondeo.
f fix
o or
r repair
d daily
02 plate tdci 130 in green.
#2 PURPLE_2L_LX
PURPLE_2L_LX
    Mondeo Mk3 Moderator
  • 16,442 posts
  • 768 thanks
Posted 03 November 2011 - 11:33 PM
Plenty of posts and pictures in this section. Some good pictures and instructions..
The basics....
Need to remove the leak off pipes and fit a pipe to each injector into a container. Run the engine at idle for 5 minutes check the levels
then run the engine at 2000 and 3000 rpm for a short while.
All 4 at the same time to compare levels.
2004 TDCi 130 LX Estate. (6)
#3 peter scott
peter scott
  • 3,110 posts
  • 289 thanks
  • Vehicle Driven:04 Zetec130TDCi Eur3
  • Name:peter scott
Posted 04 November 2011 - 03:25 PM
1. Get the engine up to normal running temperature then switch off.
2. Remove the leak back tubes from the injectors.
3. Fit the tubes from the bottles to the injectors.
4. Start the engine and let it idle for 2 minutes.
5. Give it three short bursts of acceleration up to ~3000 rpm for 30 secs.
6. Switch off the engine.
7. Check the levels in the bottles. More than 25ml in any bottle is a fail.
          2 min      ___     ___     ___
Start ______________|   |___|   |___|   |_____Stop
          Idle           Acceleration
Bottles and tubing (Total cost £10.89)
http://www.ebay.co.u...-All-Categories
http://cgi.ebay.co.u...id=573983975014
You need to chop the top 1/4" off the bottles and you should make a pin hole in the lid portion just to ensure no back pressure.
F-Super Information ..................TDCi Injector Information
TDCi Injector Cleaning................Injector Leak-Off Test
Ford ETIS........                  ..  .........Peter's other interests .............. ....
Thanked by 1 Member:
animal1978
#4 PURPLE_2L_LX
PURPLE_2L_LX
  • 16,442 posts
  • 768 thanks
Posted 04 November 2011 - 09:17 PM
I preferred the picture with 4 pop bottles. Proper DIY . :backthen:
#5 animal1978
animal1978
  • 195 posts
  • 11 thanks
  • Name:carl
Posted 04 November 2011 - 09:31 PM
thanks everyone will try this out soon.
#6 peter scott
peter scott
  • 3,110 posts
  • 289 thanks
  • Name:peter scott
Posted 04 November 2011 - 10:20 PM
You're a true Brit. Purple. I kind of like doing things on the cheap too. The pop bottles are good but not as good as the roadside "Oh, it's pouring out!" test from Romania. :}
Peter
#7 mondeotdci130
mondeotdci130
  • 3,098 posts
  • 35 thanks
  • Vehicle Driven:59 Chevvy
  • Name:Steve....Tamworth
Posted 14 August 2013 - 11:49 AM
will 6mm (ish) pipe fit on the injectors?
Formidable based near Tamworth...,
can read/code and show live data
#8 mondeotdci130
mondeotdci130
  • 3,098 posts
  • 35 thanks
Posted 14 August 2013 - 12:59 PM
/>I preferred the picture with 4 pop bottles. Proper DIY . backthen.gif
Peter
I heard he still has Whitworth spanners!, and keep a ball of string and chewing gum for the tough jobs
#9 peter scott
peter scott
  • 3,110 posts
  • 289 thanks
  • Name:peter scott
Posted 14 August 2013 - 01:56 PM
Not very tightly! 3.2mm i.d is what worked for me. See Injector Leak-Off Test below.
Peter
#10 mondeotdci130
mondeotdci130
  • 3,098 posts
  • 35 thanks
Posted 14 August 2013 - 08:09 PM
I said 6mm but i meant the plastic pipe id used for the Mr Muscle, it is not quite a tight fit on the Mr Muscle
