- Active Topics
- Forums
- News
- Reviews
- Media
Social
Regional Groups
- Scotland
- Wales
- Ireland (North & RoI)
- Bedfordshire
- Berkshire
- Buckinghamshire
- Cambridgeshire
- Cheshire
- Cornwall
- Derbyshire
- Devon
- Dorset
- Durham
- Essex
- Gloucestershire
- Greater Manchester
- Hampshire
- Herefordshire
- Hertfordshire
- Kent
- Lancashire
- Leicestershire
- Lincolnshire
- Norfolk
- Northamptonshire
- Nottinghamshire
- Oxfordshire
- Rutland
- Shropshire
- Somerset
- Staffordshire
- Suffolk
- Surrey
- Sussex
- Tyne & Wear
- Warwickshire
- Wiltshire
- Worcestershire
- Yorkshire
- Owners Clubs
- Members Garage
- Member Map
- Upcoming Meets/Events/Shows
Regional Groups
- Classifieds
- Search
- Guides
- Ford Bible
- Become A TF Supporter!
- More
More
battery drain problem 1997 escort help
Started by ian27, Nov 26 2011 11:51 AM
4 replies to this topic
#1
Posted 26 November 2011 - 11:51 AM
hi my 1997 escort ghia x, zetec engine, the battery keeps draining after about two hours and then wont start unless i use jump lead, i have changed the battery twice and the alternator, and both have been tested and they are fine, please help
#2
Posted 26 November 2011 - 05:29 PM
Hello,
When you say fine how did you check this ? When running you should get arround 14.4v at the battery. Put your hand on the relays above the fuse box is there any warm? Try the 'big' loads heated screens , could be a relay stuck closed.
Try removeing all the fuses (make a note of the positions and values, then reinsert 1 then take it out , do you notice a voltage drop?
t.
t.
2001 mk3 tddi.So far on mods..footwell lights, etac pannel ,burry handsfree,nightbreakers.t o do mudflaps and rust issuses. Died 13-6-11 rip
2006 mk3 tdci 'back to life car'' climate, powerfolds, twin bootlight, leather stering wheel and handbrake .
#3
Posted 26 November 2011 - 05:50 PM
timgdean, on 26 November 2011 - 05:29 PM, said:
Hello,
t.
t.
#4
Posted 28 November 2011 - 11:14 PM
multimeter would be a good start. , worth checking if relays do get stuck. any warm ones?
stick the multimeter on 20v on the battery and have a play.
t
t
#5
Posted 29 November 2011 - 12:58 AM
Hello,
Yep, it would need to be a very big load to pull your battery down in 2 hours, heated screen relay would also be my first port of call.
Do you get a big spark when you remove one of the battery terminals?, any big arching there would tell you something was pulling a lot of juice from the battery.
When you changed the battery, was it a new fully charged one you put on? Or was it one that you or someone else had spare? A knackered battery will often show 12v on a meter, and will happily show the 14v the alternator puts out, but it will not hold a charge, and it will be down to a fraction of it's rated amperage.
Like mentioned above, see if you get a large voltage drop when you turn something like the lights on. Charge the battery up off the car, then refit it. Check the voltage and then turn the head lights on, if the battery drops down below 12 volts it's knackered.
R reg 1997 Mondeo 2.0lt Ghia 4 Door Saloon Auto. No mods. Gearbox from a later black topped engined car successfully transplanted in place of my original box.
