Recent Topics
New From Notts.p73 - May 19 2013 10:08 PM
Advice On Buying An Ex Company CarGav80 - May 19 2013 09:32 PM
Injector Leak Off Test Kitpeter scott - May 19 2013 09:25 PM
Tyres Or Brakes?Mabok01 - May 19 2013 08:57 PM
Performance ChipsBaldrick - May 19 2013 08:43 PM
Just Filled Up The Tank - Slosh Sloshterry_mccann - May 19 2013 07:53 PM
Cant Get F-Super2 To Work.. Help?lee.collings - May 19 2013 07:46 PM
Tripple Qx Oil?Baldrick - May 19 2013 06:27 PM
Need Some Advice As I Am Looking At A Mk3 Escort To Own.nbb - May 19 2013 06:26 PM
Injectors!mr zefect - May 19 2013 06:20 PM
p1664 code & injector problems?
Started by
asti
, Jan 04 2012 09:13 PM
4 replies to this topic
#1
Posted 04 January 2012 - 09:13 PM
Hi all,
I have a 2002 tdci 130 done 130k, the coil light has started flashing, and runs a bit rough in the mornings, no smoke though, also sometimes car goes into limp mode on hard acceleration in forth and fifth gear.
codes read today P1664, fuel filter was changed 6 months back with a bosch one, and done about 5k since.
Also when I had it on the f-super I looked at the injector codes, and it showed the follwing:
injector 1 000000400004300
injector 3 90f6555580009288
injector 4 0000040000000000
injector 2 0000555520088080
Do the numbers on injectors 1 and 4 seem normal, they are basicly all 00000000's. I can't see no codes on the injector bodies to compare them either?
Any idea's?
Any idea's?
#2
Posted 04 January 2012 - 10:06 PM
asti, on 04 January 2012 - 09:13 PM, said:
Hi all,
Any idea's?
Any idea's?
Thanked by 1 Member:
#3
Posted 04 January 2012 - 10:19 PM
F-super won't read codes on pre 04 TDCI'S that's why you don't get complete codes.
You would be best to get a leakoff test done I think.
2004 Hatchback 130 TDCI Inkblue Mileage 404.000 Miles.
Genuine Ford fuel pump sprocket locking tool and pump mounting bolt tool for rent. Refundable deposit by Paypal required.
http://www.fordwiki....compatibility��
http://www.fordwiki....gory:Mondeo_Mk3
#4
Posted 04 January 2012 - 10:34 PM
Thanks Guys, Will get a leak off test done, is it easy to do? Is there a" how to" anywhere?
#5
Posted 04 January 2012 - 10:49 PM
Have a quick search through this forum there have been a few threads giving explanations on how to do leakoff tests. It isn't difficult and just needs some basic equipment to do
