stevedohc16v, on 10 January 2012 - 08:12 PM, said:
The pad warning sensors need to see an earth to keep the warning light out so a break in the wires to the pads anywhere will cause the warning light to come on, if you just need the light out I can give you the wire colour at the rear of the display that you need to earth out.
Are you sure you have checked the correct wiring? the pad warning wire is a very thin black wire with a connector plug on the suspension strut, not the thicker ABS wiring.
Hi, yes I checked the correct plugs, so from what you say if I put a continuity tester on the disconnected brake pad wires I should be able to check if I have a faulty pad sensor, out with the axle stands at the weekend then!
