problem starting
6 replies to this topic
#1 ktom
ktom
  • 4 posts
  • Vehicle Driven:cougar2 v6 2.5
  • Name:keith
Posted 17 January 2012 - 04:38 PM
hi all i got a problem with my cougar 2 v6 2001 model , my key wont start the car but all dash board lights work , if i bridge the contacts on starter motor with ignition on car will start , but car will not start by turning the key any help on this subjecf will be much appreciated thanks keith .
#2 ktom
ktom
  • 4 posts
  • Name:keith
Posted 17 January 2012 - 06:53 PM
just thought i would add that the car is a manual ,, thanks for any help , advise you can supply ,,,keith
#3 siruncle
    just imagine what i could do with something else...
  • Regional Moderator
  • 8,197 posts
Posted 17 January 2012 - 07:13 PM
are you using a proper pats chipped key?
these have a little coloured tab in the corner of them (usually red)
sounds a bit immobiliser issue to me, if you don't have a pats key, the immobiliser won't have a key signal to accept, if you have another key, try starting it with that.
2000 (w) Stardust Silver Mondy 2.0 Ghia, Big thanks to CliffH for sorting me a new gearknob :L
#4 ktom
ktom
  • 4 posts
  • Name:keith
Posted 17 January 2012 - 07:28 PM
yes mate tried both my keys still the same , i think that the immobiliser wouldnt let me start the car by bridging the contacts i also got a problem of the car cutting out at idle somtimes and the revs dropping when driving , but if i turn it of and back on while driving the car resets and works fine till the revs drop again . thanks for reply though ..
#5 siruncle
  • 8,197 posts
Posted 17 January 2012 - 08:36 PM
i presume you are aware that the 2.5 cougar is practically the same as the mk1/2/3 mondeo v6, albeit the body panels. Have you had a look through those forums?
#6 ktom
ktom
  • 4 posts
  • Name:keith
Posted 17 January 2012 - 08:47 PM
no mate not aware of that but thanks will have a look . thankyou .keith ..
#7 siruncle
  • 8,197 posts
Posted 17 January 2012 - 08:55 PM
if yours is before 2000 mk2 info will be more relevant, after 2000, mk3 stuff. :L
