Ford mondeo TDCI.. LIFT PUMP
10 replies to this topic
#1 Scott_turner
Scott_turner
    Advanced Member
  • 36 posts
  • 1 thanks
  • Vehicle Driven:TDCI Automatic
  • Name:Scott
Posted 29 January 2012 - 09:52 PM
hi there does anyone know if the TDCi 2.0 130 has a lift pump and if so where it is..
Someone says there is one in the tank
someone says its under the back wheel
the problem is as people know my mate converted my jatco automatic car to a manual car.
he warned me it was low on deisel i ignored him and yes i ran out
I got the AA to come out and they put in 10L of fuel and now the car is up to 1/4 of a tank
then got a hand pump and pulled the fuel up to the filter
sprayed easy start in it and tried for 20 mins to try and start it to no avail
and they claim its the lift pump that might of gone. as its not getting no fuel up..
Any help please... !!!
  • pessneakalp likes this
#2 PURPLE_2L_LX
PURPLE_2L_LX
    Mondeo Mk3 Moderator
  • 16,437 posts
  • 768 thanks
Posted 29 January 2012 - 09:58 PM
TDCi's shouldnt have a lift pump.
Probably needs the injectors bleeding, Airlocked.
2004 TDCi 130 LX Estate. (6)
#3 Scott_turner
Scott_turner
    Advanced Member
  • 36 posts
  • 1 thanks
  • Name:Scott
Posted 29 January 2012 - 10:00 PM
How do you do that.. the AA guy undid them all and just cranked over and over and over and said fuel shoudl come out but nothing was not...
he then did them all up apart from one and tired that
and nothing happned at all..
so does that mean the main pump is stuffed ????
#4 PURPLE_2L_LX
PURPLE_2L_LX
  • 16,437 posts
  • 768 thanks
Posted 29 January 2012 - 11:03 PM
It should run with easy start, Evil stuff it can wreck diesel engines.
How far have you driven it?
Not tripped the fuel cutoff has it? Passenger side footwell, Small round hole in the left trim panel.
I presume they have one?
#5 salta
salta
  • 5,509 posts
  • 365 thanks
Posted 30 January 2012 - 06:57 PM
they dont have an actual lift pump afaik ... but then it is a conversion . if it had a lift pump it would probably be underneath the driverside rear .sat beside the fuel tank .on in the tank .. as i say i dont think it has a lift pump though the actual injector pump lifts diesel up to the injectors ..thats why you shuldent ever let a diesel run low in fuel because it relays on a supply of diesel fuel to lubricate the innards.. anyway no fuel at the injectors is either down to these reasons sss the cutout has opperated as purple says .. the filter is empty due to a blockage or the fact that the inj.pump is now unable to suck it up from the tank . or the main injecto pump relay is shutting the pump down electrically ..as in the case when you switch off the engine with the key..this can be down to a faulty relay or key fob is faluty causing the fob to demobilize the engine .. all the above would show up on a fault diagnostic .. i recon some body wiht an fsuper would be a great help in finding whats happening ..s
#6 Scott_turner
Scott_turner
    Advanced Member
  • 36 posts
  • 1 thanks
  • Name:Scott
Posted 31 January 2012 - 12:05 PM
Hi got the car read for error codes and it came up with p1631 ..... If you spray easy start into it. it will start run for around min and then stall and only other way would be to spray it in the car and it will run. But when it stalls there is not way it will start on the starter alone you need to give it a shot of easy start..
The guy that did it just said it could be millions of things and just said that will be £5 and drove off..
but if you keep the revs up it will stay running with out a problem...
Spoke to a garage localy and he said pump for def and not to mess about with it.. and he can get me a pump for £180 recon...
#7 salta
salta
  • 5,509 posts
  • 365 thanks
Posted 31 January 2012 - 01:23 PM
yes sounds like injector pump allright .. you shuld get the guy to fit a different one that is presuming the filter has been done during the conversion . easy start is not the answer .. the pump is not lifting the diesel up to the injectors for some reason .i recon.. s
#8 danwfastford
danwfastford
  • 2,178 posts
  • 58 thanks
  • Vehicle Driven:2.0 TDCi TiTX Estate
Posted 31 January 2012 - 01:36 PM
Are you sure it's not an electrical issue? P1631 would not be flagged up if the pump was faulty. You'd probably get P1664 if it was the pump, plus P1211 as it wouldn't be able to supply the correct fuel pressure to the injectors.
£180 also seems very cheap for a recon pump?
www.fastfordmag.co.uk
Try it, you might like it!
#9 Scott_turner
Scott_turner
    Advanced Member
  • 36 posts
  • 1 thanks
  • Name:Scott
Posted 31 January 2012 - 08:24 PM
yeah i thought £180 was cheap but thats what they do them for £180 + vat... or £260 if they take it off and reaplace it...
We got it started put a brand new filter on it.
It ran fine but had this like Weeee and like a mind of its own and just like you was flooring it
well it did this for about 3 miles and now has just conked out at the side of the road starts for like 10 secs and hunts now and then
and now just died and the glow plug light is flashing but no fault codes at all now..
Puzzed totally now..
#10 danwfastford
danwfastford
  • 2,178 posts
  • 58 thanks
Posted 31 January 2012 - 10:11 PM
I'm out of suggestions unfortunately. Really surprised there are no fault codes if the EML is flashing?
