Awful MPG
8 replies to this topic
#1 graphitemondeo15
graphitemondeo15
  • 99 posts
Posted 30 January 2012 - 11:19 PM
My mondeo tdci auto has had an mpg of around 35 mpg since i bought it, recently it has dropped to 25 and only rises to around 35 mpg when i'm on the motorway, it has a known thermostat problem which i am planning to sort asap but i have never known a thermostat to cause such an issue, the car is serviced regulary, is 100% stock, i've cleaned the EGR and intake manifold to no avail, does anyone have any ideas as i could afford the car but now i cannot justify the running costs and may have to sell it.
2005 Mondeo Zetec 115 Tdci Automatic
#2 PURPLE_2L_LX
PURPLE_2L_LX
    TF's Victor Meldrew.
  • 7,598 posts
Posted 30 January 2012 - 11:37 PM
Short journey's? Kills the MPG. Winter fuel seems worse than normal also.
Do you have the fuel comp or working it out yourself?
Mine was down to 26 - 28mpg last winter. How long do you leave it ticking over to warm up and doing zero mpg?
I lost 2mpg waiting for the front heated screen to clear.
2004 TDCi 130 LX Estate. (6)
MK3 FUSE INFO CLICK HERE ......................... FORD WIKI CLICK HERE ......................... FORD ETIS CLICK HERE
Adding your location may find someone local who could offer assistance. I have an F-Super, Bluetooth OBDII (ELM) and a MS509 scanner (test subjects required).
#3 Gary Price
Gary Price
  • 417 posts
  • Vehicle Driven:Mondeo Mk3 TDCi
  • Name:Gary Price
Posted 30 January 2012 - 11:40 PM
Definitely sounds like you have a problem.
My thermostat is not as good as it should be, takes a long time to get up to temp and drops when going slow.
Even so I am still getting 55 mpg average. I only got a few mpg more in the summer.
It does depend how fast you drive but I seem to get about 60mpg at 60mph or 50mpg at 80mph.
It might be worth changing the thermostats but they are expensive. There are 2 and its recommended that genuine Ford ones are used expect about £50 for the 2.
If you had a serious engine/fuel problem the engine management light (EML) would be on.
Its possible your brakes are binding.
Jack up the wheels one at a time while cold to see if they turn freely,
Then repeat after driving a few miles. The rear ones seem to be the most common culprits.
Hand brake cables can jam and pistons can seize in the callipers.
Split turbo hoses are also worth checking for, I've not had this problem myself but usually there is a noticeable whoosing noise, loss of power but the EML light does not come on.
Good luck
Gary
#4 graphitemondeo15
graphitemondeo15
  • 99 posts
Posted 31 January 2012 - 01:30 AM
I do relativly short journeys (10 miles) commuting, but checked (calculated myself) mpg over a long run up to scotland and not any improvement. The car is parked in a garage so there is little to zero warm up time before it has an mpg above zero, checked all intercooler pipes as i had to replace the egr/intercooler pipe recently, also noticed when i took the car out last there is what sounds to me like a loud diesel knock when i accelerate for the first mile or so. Would this be a warning sign of anything? will check the brakes in the morning and any other ideas would be useful
#5 Dices
Dices
    Advanced Member
  • 46 posts
Posted 05 February 2012 - 12:26 PM
Do change the thermostat first because a cold engine pulls down MPG dramaticly and driving an engine constantly or longer than necessary below normal temp creates lots more engine wear. After you know your therm. is ok you can search further.
#6 mr_dilz
mr_dilz
  • 89 posts
  • Vehicle Driven:Mondeo 2.0TDCIGhiaX
Posted 08 February 2012 - 04:36 PM
My thermostat is also suffering from yoyo like symptoms especially when going slow or coasting downhill and the engine is not in use. Also i have noticed that my temp guage never seems to go below -2c. I know for a fact it has been colder than that when I have been driving.
03 Ghia X 2.0 TDCI
Full Leather; Lip Spoiler; K&N Panel Filter; G Welch Decat; Longlife S/Steel Exhaust; Racebits Intercooler; Forge Silicone Hoses 152Bhp/282ft-lbs Now; 170Bhp/300ft-lbs Custom ECU Remap by Racebits/Forge Motorsport
To do list: refurb alloys, Blank EGR, Steering Geometry
Repaired list: Condensor REPLACED; front discs along with pads July 10, Rear subframe bushes split replaced, turbo/intercooler pipe split REPLACED July 10, Vacuum Hoses REPLACED Nov 10, replaced boost control solenoid MAR 11, replaced clutch DMF and CSC Jan 12
"smells like an ice cream van, sounds like a tractor, but pulls like a Bullet Train."
#7 Dices
Dices
    Advanced Member
  • 46 posts
Posted 10 February 2012 - 11:00 PM
Your outside temp and thermostat are 2 different things, Outside temp is a sensor usually somewhere behind the front bumper. The thermostat is a kind of valve in the coolant of the engine. That shows 60°C and up to ( I think) 120°C on the dash. If that doesn't work properly it stays open and your coolant temp doesn't reach operational temp. especially with weather like this.
#8 Mondy55
Mondy55
    TF regular
  • 510 posts
  • Vehicle Driven:Mk3 Mondeo 2.0 TDCi
Posted 10 February 2012 - 11:29 PM
To me that sounds more like the temp gauge sender rather than the thermostat itself.
#9 mr_dilz
mr_dilz
  • 89 posts
Posted 10 February 2012 - 11:33 PM
I think I have two issues - temp guage giving not accurate temperatures - i.e. not going below -2c. I have never seen it go below -2c.
I think I also have issue with thermostat is it does reach 90c when car is warmed up, but if i drive slow or coast or go round a bend even and lift off power, then the needle does drop. I am sure this did not happen before.
03 Ghia X 2.0 TDCI
