Mondeo 2006 TDCI Smoking on acceleration
20 replies to this topic
#1 tomchill
tomchill
  • 7 posts
  • Vehicle Driven:mondeo 2006
  • Name:tom
Posted 02 February 2012 - 08:42 PM
I have put a new EGR valve on, checked all pipes for splits. I have just put in 4 new injectors but the car is still smoking any advice or ideas how to resolve this problem.
P.S. was in a Ford dealership last week for a diagnostic and no faults were found.
Thanks,
Tom
#2 peter scott
peter scott
  • 3,051 posts
  • 275 thanks
  • Vehicle Driven:04 Zetec130TDCi Eur3
  • Name:peter scott
Posted 02 February 2012 - 10:23 PM
Hi Tom,
What colour is the smoke? Black, white or blue?
Peter
F-Super Information ..................TDCi Injector Information
TDCi Injector Cleaning................Injector Leak-Off Test
Ford ETIS........                  ..  .........Peter's other interests .............. ....
#3 tomchill
tomchill
  • 7 posts
  • Name:tom
Posted 02 February 2012 - 10:35 PM
When it is very light acceleration it is white, when the turbo kicks in and under hard acceleration you get black smoke. No one seems to know what it is. I have been to delphi dealer as well as Ford dealer and none of them can find a fault.
Thanks for your reply
Tom
#4 PURPLE_2L_LX
PURPLE_2L_LX
    Mondeo Mk3 Moderator
  • 16,211 posts
  • 760 thanks
Posted 02 February 2012 - 11:53 PM
Was it the same before the new injectors? Who supplied them? Did they come with new codes?
And were they coded to the car?
2004 TDCi 130 LX Estate. (6)
#5 tomchill
tomchill
  • 7 posts
  • Name:tom
Posted 03 February 2012 - 12:11 AM
same amount of smoke as before when driving injecters was fitted at a delphi dealer. before they was fitted if u started when cold there would lots of white smoke a lot but now none and sounds a lot quieter to ps with new codes and coded to car
#6 salta
salta
  • 5,474 posts
  • 362 thanks
Posted 03 February 2012 - 05:00 AM
I would go back to that Ford dealership . if its doing what you say then the motor definitly has a fault .. either in the turbo . pipe work or the injection ..or the egr .. but eitherway that dealership is just being lazy about it .. the motor has a fault .. it smoking and not performing . i would go back and demand they diagnose the motor properly . that is not satisfactory service from a main dealership. IF howeve you dont get satisfaction the i would try blanking the egr . first anyway . it will probably throw a dash light but thats no harm it can be cleared because it wouldent be the first time a new egr .was fitted and found faluty. s
#7 Micky
Micky
  • 1,112 posts
  • 10 thanks
Posted 03 February 2012 - 07:09 AM
Op, you need to blank the EGR for greatest reduction in smoke under hard acceleration. Mine was worst on cold mornings after a few miles warming up on twisty back roads and then joining a dual carriageway. Did this for 70k miles plus, then fitted a GW blanking plate, there's still a hint on colder mornings but nothing like it was previously.
#8 tomchill
tomchill
  • 7 posts
  • Name:tom
Posted 03 February 2012 - 05:55 PM
Thanks to everyone for the replies can not do anything until Sunday will blank off EGR valve and if the same will take it back to Ford garage. I will let you know how I get on.
Thanks,
Tom
#9 Micky
Micky
  • 1,112 posts
  • 10 thanks
Posted 03 February 2012 - 07:16 PM
There's no need to tell Fruad about the blanking of the EGR (remove blank if you go back). Blank EGR, use a good fuel additive, run a couple of tanks through the thing, run it for 10 miles plus at 2k rpm plus to clear out the cr@p and then see if it smokes. I wouldn't be too concerned about smoke if the car is running OK.
Thanked by 1 Member:
tomchill
#10 tomchill
tomchill
  • 7 posts
  • Name:tom
Posted 03 February 2012 - 08:17 PM
the car runs fine after new injecters its just the smoke doing my head in. i have got a blanking plate with a 10mm hole in or should i use one without a hole in thanks for reply
