mondeo 55plate 2tdci 115b keeps cutting out glowplug?
7 replies to this topic
#1 bossko
bossko
  • 3 posts
  • Vehicle Driven:mondeo
  • Name:chris
Posted 02 February 2012 - 11:10 PM
ive got a 55plate mondeo just done 78k for the past couple month it keeps cutting out and i get a glowplug light flashing just before it cuts out as soon as i start the car back up its fine the aa cant find a problem they say its cus it isnt serious so the ecu doesnt save the error code ive taken it to a garage and had injectors replaced and the cam shaft sensor.still got the problem now the garage are saying it just needs a ecu upgrade as the injectors can lose there memory but they said that the update as glitches in at the moment that ford are working on can anybody else show me any light please the car has been a dream to me for couple years but its getting annoying now keep cutting out for no reason
#2 PURPLE_2L_LX
PURPLE_2L_LX
    Mondeo Mk3 Moderator
  • 15,979 posts
  • 745 thanks
Posted 02 February 2012 - 11:39 PM
Cutting out with no fault codes could be, Dodgy cam/crank/flywheel sensor.
Normally a flashing glowplug will leave a fault code, But it may reset after so many engine restarts.
Avoid any garage that say the glowplugs are faulty. They are only needed to get it started and will usually start fine without them,
But will run a bit lumpy until warmed, Not recommended though.
If you have a laptop you can get an F-Super code reader off ebay, You can read and reset codes read live data and also
on a 55 plate car program your own injector codes.
2004 TDCi 130 LX Estate. (6)
#3 stevegtuk
stevegtuk
    Steve
  • 3,670 posts
  • 125 thanks
Posted 02 February 2012 - 11:44 PM
Is it cutting out completely or going into limp mode. Mine used to go into limp and flashing glow plug, then when i turned it off and restarted it worked fine, It turned out to be the turbo actuator. The trouble was when i turned the ignition off and back on it reset the system in someway so the error didnt show up when i took it in t be checked. Only found it out what it waswhen i took it in with the glowplug still flashing.
Mondeo 06 Panther Black tdci 115 Estate lx (becoming more).
Already fitted:
Sony mp3 radio, Uv shades all round, Wind deflectors, Front Fogs, Flyeyes on taillights, Reversing camera and monitor in mirror(homemade setup £35), C-max sunglasses holder, Rear leccy windows and appropriate door cards, Led strips in footwells and boot area, full sized spare, rear courtesy roof light, led indicator strip front and indicator/sidelights and brake, puddle lights, led spot light on towbar, white led strip behind rad grill to come on with sidelights, and a few more besides
Waiting to be fitted
To be decided
#4 bossko
bossko
  • 3 posts
  • Name:chris
Posted 03 February 2012 - 08:02 PM
hi at 1st u wouldnt even know it cut out untill u put ur foot down if u was at lights ect but lately u can be doing about 60 then it feels like it just stops then it it all of a suddenly kicks back in then the glowplug comes on then it just rolls to a stop then as soon as i turn it back on its fine the aa bloke said that because i keep restarting the car it wipes the error code because it isnt a major issue the ecu wont save it thats why the glowplug light doesnt come back on when i restart the car im getting told it just needs a ecu update but ford are having issues at the moment with the update but is this true
#5 Mabok01
Mabok01
  • 3,001 posts
  • 257 thanks
  • Vehicle Driven:Mondeo TDCI 130 2004
  • Name:Michael
Posted 03 February 2012 - 08:34 PM
Whatever you do don't take it to ford. Find a good independant diesel specialist instead.
Ford will just replace all the expensive parts until they cure the problem or you give up. My local dealer outsources all their diesel problems to a local independant cause they haven't a clue apart from servicing.
What year is a 55 plate? invest £20-30 in an F-super for a laptop if you have access to one and read the codes yourself if you can then come back to us with info.
Many here will recommend you first change your fuel filter for a quality replacement <Ford/Bosch/Delphi and then go from there.
2004 Hatchback 130 TDCI Inkblue Mileage 443.000 Miles.
Genuine Ford fuel pump sprocket locking tool and pump mounting bolt tool for rent. Refundable deposit by Paypal required.
#6 bossko
bossko
  • 3 posts
  • Name:chris
Posted 05 February 2012 - 05:31 PM
would a fuel filter make that much diffrence for the engine to cut out ect when it starts up it does sound a lot diffrent sounds like a bag of nails now everytime i take it to the shop it always seems to be something diffrent that they try and replace its makeing me wonder like the comment above are they just hopeing they find the problem
#7 Mabok01
Mabok01
  • 3,001 posts
  • 257 thanks
  • Name:Michael
Posted 05 February 2012 - 09:39 PM
There is no guarantee a filter will cure it but it is a first step in narrowing down your problem. If the filter isn't allowing fuel to flow at a high enough rate the ecu will sense this and put the engine into limp mode or flash the glowplug light.
#8 salta
salta
  • 5,449 posts
  • 361 thanks
Posted 06 February 2012 - 01:09 AM
id also check the starter motor for fillings . you have to take it out unfoutunatly . if the head of the starter motor is covered in filling s and when you put a flat bladed screwdriver on the teeth of the flywheel through the starter motor aperture [ place where it fits ..] and try to move the flywheel ..if you get more than an eight to a quarter inch play on the teeth backwards anf forwards then the flywheel is fubar . s
