EGR - Clean or delete?
egr judder clean
6 replies to this topic
#1 itiejim
itiejim
  • 3 posts
  • Vehicle Driven:S-Max 2.0 TDCI
  • Name:James Ashton
Posted 11 February 2012 - 11:07 PM
Hi folks, I've got a bit of a judder coming from my '07 S-Max 2.0 TDCI when under load at about 1750 rpm. Google seems to indicate that this is likely to be an EGR issue. I'm inclined to remove the EGR and the inlet manifold to remove 50k miles of rubbish but wondered if there was any benefit in deleting the EGT whilst I'm at it?
I guess it will throw an engine management light, is there any way this can be kept off?
#2 siruncle
    just imagine what i could do with something else...
  • Regional Moderator
  • 8,209 posts
Posted 11 February 2012 - 11:17 PM
as its euro 4 nothing can be done about the light at the moment if you remove the egr completely. Best thing at the moment is a good clean. :L
there's a member who is looking at an egr eml defeat but its early days yet.
2000 (w) Stardust Silver Mondy 2.0 Ghia, Big thanks to CliffH for sorting me a new gearknob :L
#3 itiejim
itiejim
  • 3 posts
  • Name:James Ashton
Posted 11 February 2012 - 11:18 PM
That's great, thanks.
Are there any guides around on how best to access the EGR - isn't it hidden down the back of the engine?!
#4 siruncle
  • 8,209 posts
Posted 11 February 2012 - 11:23 PM
there is a wiki for the tdci engine, if you have the same engine it will be ideal, but if yours is the later psa diesel engine it'll be different although the job will be similar. http://www.fordwiki....d_Clearout_TDCi
#5 itiejim
itiejim
  • 3 posts
  • Name:James Ashton
Posted 11 February 2012 - 11:28 PM
#6 mach1rob
mach1rob
  • 46 posts
Posted 29 February 2012 - 01:00 PM
It may not be the EGR, and may be down to one of the Pierburg valves bolted to the side of the block, just above the gearbox. One of ours has packed up, and we get a judder/stutter around the same rev range. One controls the turbo (rear one) the other various vacuum items, and it's this one that's died on ours.
I've blanked off the EGR by inserting a plate in the pipe from EGR to inlet, there's a seller on ebay that does them for around a fiver. It's worth cleaning as much crud out as you can as it's thick horrid gloop and can't do anything much good.
2001 LX TDDi saloon, ex Starship Enterprise.
#7 Mondy55
Mondy55
    TF regular
  • 514 posts
  • Vehicle Driven:Mk3 Mondeo 2.0 TDCi
Posted 29 February 2012 - 02:59 PM
I have a Mondeo 2.0 TDCi (Mk3) and recently cleaned out my EGR valve after reading about them on here. If you're thinking it might not be worth doing as it may not solve your problem, take a look at the thread below, showing the EGR and manifold from my car with 60,000 on the clock. My car now starts better and runs noticeably better, particularly in 1st gear where it was a little chuggy before at low speed. I'm glad I did it, and I'll do it again when it gets to 80,000 or so.
http://www.talkford....e-and-manifold/
