Temperature control is not working after replacing Sony radio with travelpilot fx
mondeo travelpilot fx sony
3 replies to this topic
#1 peppino
peppino
  • 7 posts
  • Vehicle Driven:Mondeo 2009
Posted 18 February 2012 - 08:27 PM
Hi,
I've replaced Sony radio with Blaupunkt travelpilot FX navi/radio unit on my Mondeo MK4 2009. I didn't go to Ford dealer to do any software changes.
CD, radio, AUX, Bluetooth and voice control is working perfectly. Not sure about navigation because I haven’t buy the SD maps yet.
Problem is that after this replacement the climate temperature control is not working. The heaters are still heating although the temperature is set to the lowest. Even if airco is enabled I don’t feel any cool air coming from the exhausts.
I suspect that the issue is in the software configuration.
a) After such replacement does the firmware have to be upgraded?
B) Could be the problem with heating system related to the this change?
Thanks for any advice.
#2 Mondeo-hopeful
Mondeo-hopeful
  • 3,359 posts
  • 159 thanks
  • Vehicle Driven:Tit X Sport 4
Posted 19 February 2012 - 10:47 AM
No mods required to cc, after sat nav retrofit.
I'd pull the battery negative off for a few minutes and try again. Also if not resolved get behind the cc unit and check the connection.
BLUETOOTH MODULE INFO www.talkford.com/topic/147387-please-help-for-btvc/page__p__1403226#entry1403226
Check your CONVERS+ version www.talkford.com/topic/154824-convers-versions/
Check your SPECIFICATION on ETIS here http://www.etis.ford...5707F2.fcvas509
To search the forum more effectively go to google.co.uk add the following to the search box :site talkford mondeo mk4 <your query> e.g :site talkford mondeo mk4 bluetooth
09 2.2 Tit X Sport, Hypno Silver, options are keyless entry, privacy glass, 8 Way Powered Drivers Seat
Thanked by 1 Member:
peppino
#3 mifalc
mifalc
  • 6 posts
  • 1 thanks
  • Vehicle Driven:Mondeo 2,0 Titanium
  • Name:Michael Falconakis
Posted 21 February 2012 - 10:40 AM
Hi there , I own a Mondeo Titanium MK4 2009, and made myself the same replacement as you did , and also retrofit a USB port.
Everything works fine without any firmware change.
Just check the climata connections again..
peppino
#4 peppino
peppino
  • 7 posts
Posted 21 February 2012 - 11:15 AM
Thank you guys!
Also tagged with one or more of these keywords: mondeo, travelpilot fx, sony
