Recent Topics
Shocked to say the leastSheffSean - Today, 07:32 AM
AlarmPURPLE_2L_LX - Yesterday, 11:03 PM
Main Beam FaultMagnumMondeo - Yesterday, 10:43 PM
Ford NX Nav Map updatesVintageWillis - Yesterday, 10:35 PM
Electronic egr valve mondeo tdciHenners123 - Yesterday, 09:37 PM
Heater/AC Blowerscuboo - Yesterday, 08:19 PM
Wanted DVD Headrests Full System Wanted MK3 MondeoBenporter139 - Yesterday, 07:27 PM
Mondeo TDDI take apart guide youtubeAlbi - Yesterday, 07:19 PM
ALLOY PEDAL COVERSKAZUYADOG - Yesterday, 06:51 PM
Oil leak tdci mondeoPURPLE_2L_LX - Yesterday, 06:49 PM
Renovating tools.
Started by
Mabok01
, Feb 19 2012 09:46 PM
5 replies to this topic
#1
Posted 19 February 2012 - 09:46 PM
Not too sure if anyone can help with this but here goes.
Found myself in a car boot sale today and picked up a draper expert set of Torx and Alan key bits for a pound. Nearly complete but the box is trashed and has been closed up at some point with the bits wet. My question is does anyone know a good way to remove the rust or is it just a question of rubbing down with fine wet and dry? Some of the rust is heavy and flaky and some just light surface rust. Oh and is there any way of treating them to stop it coming back?
2004 Hatchback 130 TDCI Inkblue Mileage 404.000 Miles.
Genuine Ford fuel pump sprocket locking tool and pump mounting bolt tool for rent. Refundable deposit by Paypal required.
Injector information
FordWiki
FordWiki
#2
Posted 19 February 2012 - 10:07 PM
soak in wd40 for a day or two, most of it will come off, most surface rust will come off, the only way to treat the tools would be to have them shotblasted, and re-coated with something like zinc or chrome plating or galvanised.
Thanked by 1 Member:
#3
Posted 19 February 2012 - 11:14 PM
Lots of heat is also good for rust...propane mix or map gas. (Was a tip on The salvager that used to be on sky, amazingly it works)
I have to admit I hate rusty/dirty tools so I clean and oil em now and again.
Ford Mondeo Mk3 Estate Automatic in Oyster Silver - Modified and Upgraded
Common faults and guides for most Fords can be found in the:- TalkFord Wiki Guide
Ford Etis Online Technical Information:- Ford Etis
Greater Manchester Regional Group
Covering Stockport, Tameside, Oldham, Rochdale, Bury, Bolton, Wigan, Salford, Trafford
#4
Posted 19 February 2012 - 11:50 PM
Electrolytic Rust Removal.
A small battery charger (6amp ish.) A plastic tub, Bicarbonate of Soda, A lump of steel (sacrificial)
Put enough water in the plastic tub to cover the items to be derusted, Add a few spoons of bicarb and mix.
Put the sacrificial steel in the water with enough material out of the water to put the positive crocodile clip on, If the clip enters the water it will rust.
Place the rusty item or items in the water and connect the negative crocodile clip into that/them. Wire several pieces together if required.
Switch on the charger and watch the bubbles (hydrogen gas, flammable) so vent well. After a few minutes you will see the rust moving from your
tools to the sacrificial metal.
Causes no damage to the rusty item that the rust has not already. Safest way to derust a lot of items.
As soon as you take it out of the water you MUST protect them right away or they will rust quickly.
2004 TDCi 130 LX Estate. (6)
#5
Posted 20 February 2012 - 12:34 AM
I use Bilt Hamber deox gel.
Current Mondeos are:
53 Ink Blue ST220 estate
97 Panther black 2.5 ghia X saloon
And my other toys are:
1994 Ford Escort RS2000 4x4
1987 Ford Capri 2.8i special
1998 Ford KA2 & 1998 KA3
#6
Posted 20 February 2012 - 12:17 PM
Thanks for the replies guys.
Stevedohc16v that gel stuff looks brilliant have to give that a try.
I try and buy good quality second hand tool when I see them so i have a few around that could benefit from some of that gel.
FordWiki
FordWiki
