- Active Topics
- Forums
- News
- Reviews
- Media
Social
Regional Groups
- Scotland
- Wales
- Ireland (North & RoI)
- Bedfordshire
- Berkshire
- Buckinghamshire
- Cambridgeshire
- Cheshire
- Cornwall
- Derbyshire
- Devon
- Dorset
- Durham
- Essex
- Gloucestershire
- Greater Manchester
- Hampshire
- Herefordshire
- Hertfordshire
- Kent
- Lancashire
- Leicestershire
- Lincolnshire
- Norfolk
- Northamptonshire
- Nottinghamshire
- Oxfordshire
- Rutland
- Shropshire
- Somerset
- Staffordshire
- Suffolk
- Surrey
- Sussex
- Tyne & Wear
- Warwickshire
- Wiltshire
- Worcestershire
- Yorkshire
- Owners Clubs
- Members Garage
- Member Map
- Upcoming Meets/Events/Shows
Regional Groups
- Classifieds
- Search
- Guides
- Ford Bible
- Become A TF Supporter!
- More
More
15 replies to this topic
#1
Posted 20 February 2012 - 07:18 PM
Hello everyone, maybe somebody ever had changed piston rings with engine in it. Any chance doing it, i had flushed engine several times, but still where is oil on cylinder number 4, I had changed valve stem seals, did everything apart rings, Thanks in advance
#2
Posted 20 February 2012 - 07:25 PM
its a sump off job, and iirc crank out. sounds easy but the subframe is probably in the way too. Its probably less grief to remove the engine out the top, then operate as it isn't fun operating overhead under the car.
while its out, its a good opportunity to check or deal with the inlet manifold flaps, as you can get at the bolts
2000 (w) Stardust Silver Mondy 2.0 Ghia, Big thanks to CliffH for sorting me a new gearknob
#3
Posted 20 February 2012 - 07:42 PM
#4
Posted 20 February 2012 - 08:04 PM
maybe oil control ring is damaged.
#6
Posted 23 February 2012 - 02:08 AM
Compression test wont show a sticky or worn oil control ring. Lets you know if compression is down but oil rings
wont really affect that.
You will only really tell after stripping it. See if the rings are still springy or gummed up.
2004 TDCi 130 LX Estate. (6)
MK3 FUSE INFO CLICK HERE ......................... FORD WIKI CLICK HERE ......................... FORD ETIS CLICK HERE
Adding your location may find someone local who could offer assistance. I have an F-Super, Bluetooth OBDII (ELM) and a MS509 scanner (test subjects required).
#7
Posted 23 February 2012 - 11:14 PM
#8
Posted 24 February 2012 - 05:46 PM
Does somebody knows, what torque is pistons tightened to? I have replaced all rings, now I just need to tighteen them
#9
Posted 24 February 2012 - 09:00 PM
as in the conrod bolts?
#11
Posted 25 February 2012 - 01:27 AM
Did you position and gap and position the rings properly??
Seen a few that have been fitted poorly and they wonder why it burns as much oil after replacement.
Were the old rings worn or gummed up?
Head Bolts:
Stage 1...5Nm 4lfb ft
Stage 2.....15Nm 11lbf ft
Stage 3.........45Nm 33lbf ft
Stage 4.............Angle tighten 90 degrees
Stage 5..................Angle tighten 90 degrees
Head Bolts:
#12
Posted 25 February 2012 - 09:24 AM
Head Bolts:
Head Bolts:
#13
Posted 25 February 2012 - 09:31 AM
I hope I did everything right
#14
Posted 25 February 2012 - 08:40 PM
I'm a petrol head
04 Mondeo Ghia x 2.5 v6 vroom vroom not broom broom.
Defender + horse when in the Andes Peru,
Worked with diesel cars and trucks for over 40yrs no intentions of owning one for pleasure
previous 1999 mk2 2.0 Ghia x 1998 mk2 2.0 1998 mk2 1.8 estate. In the days when I had money 1990 BMW 7 series, 1960s alfa Romeo Spider boat tail, When I was a boy racer 1960/70s Escort RS turbo, Mk1 Lotus cortina, E type. More motor bikes than most people have had hot dinners?
#15
Posted 25 February 2012 - 11:09 PM
Did you step the gap/split in the rings?
