Recent Topics
Hi Frim Sunny LancashireBaldrick - Yesterday, 10:27 PM
Front Grinding Noisesalta - Yesterday, 10:08 PM
Leaking Windscreen - Opinions Needed!ST56 - Yesterday, 09:55 PM
Mondeo Mk4 2.0 Ecoboost 240Ps - Anyone Chipped Theirs?Nick - Yesterday, 09:27 PM
St220 Front WingsFITZYNKAZ - Yesterday, 09:24 PM
Oil FiltersM1CH431 - Yesterday, 09:17 PM
High Revingleechalk - Yesterday, 08:38 PM
Tesco Tyres.EvoUK - Yesterday, 07:50 PM
Tdci Fuel Line Help.salta - Yesterday, 07:38 PM
1.8Tdci Engine Failure Discussion Threadbailes1992 - Yesterday, 07:36 PM
turbo wanted mondeo mk3 tddi
Started by
gary jacko
, Mar 17 2012 09:36 PM
11 replies to this topic
#1
Posted 17 March 2012 - 09:36 PM
As title says need a turbo cheap as mine has split in two!
#2
Posted 17 March 2012 - 09:45 PM
which type variable vane or fixed vane?
i havent got one but could help you out in pointing you in the right direction
do you know if you have a maf sensor on your car? i can tell which turbo it is then.
im guessing your after a used one and im also guessing your casing on the turbo has had it?
#3
Posted 17 March 2012 - 09:52 PM
Variable vane.
second hand. not wanting to spend a lot. dont kno if anything got into engine yet. just wondering anyone got one hidden away.
yeh the compressor housing has completely come away from exhaust side!! tottaly out of blue
#4
Posted 17 March 2012 - 10:01 PM
i can tell you the tdci 130 turbo will also fit as its the same regardless of part numbers basically as long as it looks the same it will fit. also the 2.2 turbo will fit too its essentially the same but the wheels have extra fins on them.
obviously turbo's with electrical black box on them wont fit and this type which i have wont either
the above type would fit and would likely work but god knows what your dash would do and your ecu would probably have codes on it so best sticking to what will fit lol.
#5
Posted 17 March 2012 - 10:05 PM
Your turbo is pretty much similar to a transit turbo i think. bloke at work fit one to his mondeo. Binned all the egr vac control etc. works fine but wudnt want to mess around like that.
dont wanna b messing with electronic actuators lol enough trouble with mondeos as it is!
#6
Posted 17 March 2012 - 10:07 PM
i heard about someone ditching egr cooler somewhere in here.
my turbo fits tddi of course and most tdci 115 models
#7
Posted 17 March 2012 - 10:14 PM
Remains of my turbo
#8
Posted 17 March 2012 - 11:08 PM
#9
Posted 18 March 2012 - 11:00 AM
what a mess
hopefully the engine is ok.
when mine went it didnt get that far but i decided to go for a hybrid which is basically a recon/new unit. for me i wouldnt risk second hand but not everyone has that option.
ill make a suggestion though once its sorted only use ford formula f 5/30w in the engine its the best oil for the engine better than magnatec. £22 for 6 litres off ebay.
#10
Posted 18 March 2012 - 01:10 PM
Can u put a link to the oil tg
ST 220 in panther black only mods so far
oem blackeyed xenons,facelift dash with sony 6 cd, facelift screen,all chrome trims inside and out ,powerfolds facelift variable red recaro leather interior and a big fook off engine under the bonnet
:D V 6 RULES END OF :D
#11
Posted 18 March 2012 - 04:44 PM
It gets ford oil but it costs me a lot less than that.
i work for a ford dealer im a transit tech
#12
Posted 18 March 2012 - 05:09 PM
seems to have gone up!! http://www.ebay.co.u...=item35b44b6c44
i better start looking where i can get it local as mine will need doing soon
