Recent Topics
mk2 Galaxy uses excessive fuel & hard to start
excessive fuel poor mpg
4 replies to this topic
#1 74andyr
74andyr
  • 2 posts
  • Vehicle Driven:Galaxy mk2 2.3
  • Name:Andy
Posted 30 March 2012 - 01:27 PM
Ford Galaxy mk2 2.3 petrol is difficult to start and using excessive fuel, approx 6/7 mpg.
This started  (or i first noticed)  this approx 1 week after it was in the garage for a minor rattle & service due.
Work carried out:
Full service and timing chain tensioner was changed.
Have checked for fuel leaks & nothing.  Been back to garage & asked if it could be he has set up timing wrongly but they say prob fuel injetor fault & not related to the work just done.
Appreciate any help, thanks
#2 Mirez
Mirez
    Administrator
  • Administrators
  • 13,733 posts
  • 11 thanks
Posted 30 March 2012 - 04:08 PM
Sounds suspiciously like a timing problem to me, you might have to get another garage to diagnose the problem and then claim it back if the continue to deny its even a possibility... :(
03 Ford Galaxy 1.9 TDI 130 Ghia in Spuce Green Metallic
______Too many changes to list: Click here to come and look instead!
______
10 VW Golf BlueMotion 1.6 105 TDI SE Estate in Platinum Grey
______Most VAG applications - Scans/Coding done in exchange for a bag of winegums :)
#3 74andyr
74andyr
  • 2 posts
  • Name:Andy
Posted 30 March 2012 - 04:30 PM
Thanks for your advice. Can you think of anything else it could be that a fairly decent diy mechanic could check in order to rule them in or out?  Or any tests to rule timing in or out?
Many thanks
#4 Mirez
Mirez
    Administrator
  • Administrators
  • 13,733 posts
  • 11 thanks
Posted 30 March 2012 - 06:57 PM
The 2.3 was derived from the sierra and fitted to the Scorpio and Transit so have a rummage around those forums and you may find some more info as I'm not that clued up on the tbh. A great PDF is here:
http://www.fordscorp...2300CylHead.pdf
Scroll down to 58 and it shows where all the timing marks are so you may well be able to get to the chain and see for yourself.
______
#5 car-nut-86
car-nut-86
    TF regular
  • 1,165 posts
  • 15 thanks
  • Vehicle Driven:Mondeo 2.5 Ghia X V6
  • Name:CJ
Posted 09 May 2012 - 11:25 PM
Have you had a diagnostics check?  Is the engine running ok once it is going? Also try changing RELAY 30. That seems to be the MOST common problem with Galaxy's for non starting. It is a digifant relay and can be bought from either VW or Ford and is located on a relay fuse board behind the fusebox under the steering wheel.
My Daily Runner & Top Project: Maroon 2002 Mondeo Estate Ghia X 2.5 V6
My Project: Black 2003 Mondeo Graphite TDCi 115 Estate
