Recent Topics
Key Fob CodingAndy76 - May 22 2013 10:10 PM
Odd Light Problem...engrush - May 22 2013 10:06 PM
Thanksmarty3 - May 22 2013 09:03 PM
"easy-Fill" Fuel Problemsandyrev1 - May 22 2013 09:01 PM
Catalytic Converter Faultsthegfb - May 22 2013 08:25 PM
St200 / Regular V6 Mondeo Ecu WiringsMikkoMuhis - May 22 2013 07:03 PM
Temp FixPURPLE_2L_LX - May 22 2013 06:27 PM
2.5T Running Out Of Patience!Marky68 - May 22 2013 06:09 PM
What They Worthstevegtuk - May 22 2013 05:46 PM
Mot Failure: O/s Rear Ball Joint Bush Deterioratedebrapup - May 22 2013 04:46 PM
blue smoke
Started by
Neris
, Apr 04 2012 12:24 PM
3 replies to this topic
#1
Posted 04 April 2012 - 12:24 PM
Hello everyone who have Ford Galaxy reg 2007 2l deesel.
I have a little problem but no one can tell me how to fix it. Every time in the morning ,when I start the engine there is blue smoke comming. When the engine is warm nothing happends at all. can it be the glow plugs?
We change the injectors and fuel filter ,but no help...
Thank you Neris
Thank you Neris
#2
Posted 08 April 2012 - 03:23 PM
I have seen this happen before in other vehicles and been told that it is the engine pre-heaters. I can't guarrentee this but it might be worth looking into
Thanked by 1 Member:
#3
Posted 30 April 2012 - 12:43 AM
Blue smoke is normally signs of piston rings, but like elthria says a lot of new vehicles do this on start up. As long as you are not using any oil and the blue smoke tops once the engine is warm I wouldn't worry too much.
My Daily Runner & Top Project: Maroon 2002 Mondeo Estate Ghia X 2.5 V6
My Project: Black 2003 Mondeo Graphite TDCi 115 Estate
#4
Posted 02 September 2012 - 09:12 PM
Hi ya.
Like the previous person said so long has you are not using any oil. Live with it. However if you are it could be valve stem seals, while the vehicle is left the oil is running down the valves and when you start the engine it is being burnt away. Hope this helps.
