Recent Topics
Dull Headlightsraveboy2012 - Yesterday, 11:31 PM
To Add Or Not To Add?bender7 - Yesterday, 11:19 PM
Knocking Sound From Rear When Going Over BumpsMondeoLXOwner - Yesterday, 09:05 PM
Wiring ProblemPURPLE_2L_LX - Yesterday, 08:58 PM
Coolant Leak Mk2 2.0 BlacktopSquirt - Yesterday, 08:45 PM
Rear Arm Rest Cupholderpeebee - Yesterday, 08:43 PM
Steering RackUnder The Gun - Yesterday, 07:46 PM
Mondeo Dab To Blaupunkt Sat Nav Help NeededMegansbob - Yesterday, 07:16 PM
Brake Pipes Separate From Rear?Baz100 - Yesterday, 05:40 PM
Dimming Rear View MirrorCurlyben - Yesterday, 05:28 PM
Black eye headlight help.
Started by
Bungle 123
, Apr 05 2012 11:05 PM
3 replies to this topic
#1
Posted 05 April 2012 - 11:05 PM
hi, at the begining of the week i took apart both headlights and sprayed the insides black and the put them back togeather and let them dry over night in the airing cupboard. when i come to put them on the next day i noticed that when i took them outside there was condensation inside the headlamp.... so i removed them that night to let them dry a bit more cause i thought it may have been the moisture from the silicone i used.. next morning i look at them and they were clear so i put them back on my car, but they then started to mist up again.... is there anyway to fix this problem? thanks
#2
Posted 06 April 2012 - 09:58 AM
ive done loads of them and never had that problem. did you touch inside the light lens? if so did you clean it thoroughly. also you shouldnt have done it the way you mention above what you should have done is take off the lens and take the front part out then paint it then put it in the airing cupboard overnight then refit it the next day
i think the solvents in the paint are causing the condensation that and/or dirty inside the lens. the paint needs to breathe as it dries, the solvents are coming out of the pqaint the most for the first day and they still come out after they are dry also
as for sealing you should use a bead of gasket sealer or silicone or tiger seal 2-3mm on the frame of the light any more and it will ooze out.
#3
Posted 06 April 2012 - 12:41 PM
thanks for the reply..... Oh i got you. well after i painted the lens black i waited about an hour for it to dry then put it back togeather. I also used some white sprit on the inside of the lense to get any dirty of but i used a cloth to dry it off with. will i have to seperate the lights again to solve the problem?
#4
Posted 06 April 2012 - 12:50 PM
when you put the lights in the airing cupboard did you leave the rear panel open ??? ( if you did then it should have let most of the moist air from the piant still drying get out etc, if not then that may be the problem, its got loads of moist air inside it )
if not then hair drier pointed in to the back or AC vent inside the car ( one per footwell to fill the lamp with dry air & it should sort the problem out of a while & a big pack of the silicon pellet stuff may also help too but the fogging should settle down after a while.
