Recent Topics
Potential Gearbox Issues - 2004 1.9TDi
gear box tdi clutch gearbox engine management
No replies to this topic
#1 elthria
elthria
  • 2 posts
  • 1 thanks
  • Vehicle Driven:Galaxy
  • Name:Alexander Boyle
Posted 08 April 2012 - 03:20 PM
I recently had the wiring loom to the fuel injecters replaced and the extra power stripped the clutch which had to be replaced since then I have been having issues with what i think is the gearbox. It doesn't happen every time but it is regularly getting stuck in gear. especially reverse. even with the clutch fully depressed. The main symptom appears to be that the gear stick will not disengage the gear no matter how much strength I use. Yet if i let go completely and release the clutch then try again it works like it should.
Has anyone else had issues like this and does anyone know what the problem is?
Also tagged with one or more of these keywords: gear box, tdi, clutch, gearbox, engine management
