Recent Topics
AlarmPURPLE_2L_LX - Jun 19 2013 11:03 PM
Main Beam FaultMagnumMondeo - Jun 19 2013 10:43 PM
Ford NX Nav Map updatesVintageWillis - Jun 19 2013 10:35 PM
Electronic egr valve mondeo tdciHenners123 - Jun 19 2013 09:37 PM
Heater/AC Blowerscuboo - Jun 19 2013 08:19 PM
Wanted DVD Headrests Full System Wanted MK3 MondeoBenporter139 - Jun 19 2013 07:27 PM
Mondeo TDDI take apart guide youtubeAlbi - Jun 19 2013 07:19 PM
ALLOY PEDAL COVERSKAZUYADOG - Jun 19 2013 06:51 PM
Oil leak tdci mondeoPURPLE_2L_LX - Jun 19 2013 06:49 PM
Induction kitsK-bizzle84 - Jun 19 2013 06:43 PM
Limp mode issues flashing Coil light
Started by
Cadairmanuk
, Apr 13 2012 08:35 PM
48 replies to this topic
#1
Posted 13 April 2012 - 08:35 PM
Hello every one.
I have a problem with my 2002 mondeo tdci 130bhp. Today it went into limp mode with the coil light flashing on the dash board. I have just bought a code reader so waiting on that but in the mean time is there anything I can try to rectify the problem? The car has done 85k with full history been in the family for 4 years with no issues. Its just had a full service last week. The engine revs freely on tick over , no smoke and starts ok and the car has been running really well up to this point. Tonight I disconnected the battery and left for 30 mins but the light was still flashing even before the car was started. What's my next move?
Ben
Ben
#2
Posted 14 April 2012 - 08:23 AM
I have just tried starting it no joy and smoking like a chimney blue smoke. Any initial ideas?
Ben
Ben
#3
Posted 14 April 2012 - 08:39 AM
It is very hard to say any thing without reading the error code. There could be few issues but lets wait for the error code. On the first i might say it is about injector(s) or fuel pump but there can be another causes.
Something is wrong with my Ford today but I don't know what it is
Mondeo Mk3 2.0 TDCi 130 HP
#4
Posted 14 April 2012 - 08:48 AM
Ok then I'll sit tight I have another car so it can site and wait.. I will be back with my fault codes. The car was running and sounded mint even in limp mode ,would it be running rough if it was injectors? Egr valve possibilities? I guess from looking on the forums it could be a host of things
Ben
Ben
#5
Posted 14 April 2012 - 07:27 PM
HI Ben . the first thing that springs to mind is .the motor has just been serviced. this may point to something that was done in the service that did not go well with the engine . so the most common cause for this may be fitting a wrong fuel filter . . if a bosch .delphi or motorcraft .ie ford filter is not used then fuelling problems can arise from using spurious makes of filter .. soo . check the fuel filter is one of these makes then also check if the fuel filter is actually filling up with fuel and to do this simply take off the return pipes an look down int ot the bigger opening you shule see fuel . if you dont then try refilling the filter manually though the inlet to the filter , right up to the brim.. then check all the three connections on top of the filter for tighness and for being clipped home properly . .. as for clearing the fault code light this you can do when you get f super .. some flashiing code light dont clear by simply disconnecting the battery for half and hour some have cleared then by disconnecting over night . but radio codes will be lost so make sure you havve you r radio code if you do this . s
#6
Posted 15 April 2012 - 12:56 AM
What code reader did you purchase? Cheap handheld readers wont work on early cars.
You need something like the F-Super off ebay for £24 ish. But it needs a laptop (USB port and software)
Cheapest handheld unit that will work is about £150.
Without a fault code or live data your chasing your tail looking for the fault. Unless you stumble across it
by accident.
by accident.
2004 TDCi 130 LX Estate. (6)
#7
Posted 15 April 2012 - 05:13 PM
I bought this http://www.ebay.co.u...#ht_2204wt_1185 hope it gives me the info I need. Car wont start at all trying to fire but wont start up. Hopefully the lead should be here tomorrow or tuesday.
Ben
Ben
#8
Posted 15 April 2012 - 08:52 PM
Sorry but that reader wont work on your 2002 car. ELM works on diesels from 2004 onwards.
You need an F-Super.
This....
http://www.ebay.co.u...=item1c25c95e88
This....
Thanked by 1 Member:
#9
Posted 15 April 2012 - 09:04 PM
Ah man you joking? I will have to send it back then and get the other. Doesn't say anything about the years which is annoying. You would think they would clearly state 2004 onwards or words like that!! Ok thanks for the heads up , looks like a few more days wait
Ben
Ben
#10
Posted 16 April 2012 - 12:48 AM
Yeah bit of a crap listing, If you check other ELM interfaces they usually say diesels from 2004 onwards.
The F-Super will work on a 2002 car, MIne works on my sisters. Cant read or code the injectors though.
But does read/clear codes and shows live data.
#11
Posted 20 April 2012 - 04:37 PM
Well I'm still waiting for the correct lead to come which is a pain should have been here Wednesday. In the mean time my mate popped round with his snapon gadget from work and recons its a cam sensor. I could see on his machine something like above threshhold knock or something. Just wondred if a cam sensor would prevent starting? it's a grey one which I'm told is ok. Can I swap it with my 07 plate transit 2.4 to check looks the same sensor.
Ben
Ben
#12
Posted 20 April 2012 - 05:43 PM
Swapped cam sensors just the same. My cam sensor works fine in my transit.
#13
Posted 20 April 2012 - 08:06 PM
Latest up date after today. Car started eventually and ran a little lumpy around 1500rpm loads of blueish smoke i think it was un burnt fuel after struggling to start. Tick over fine and revs out fine. Coil light still flashing. Took it for a spin well under powered still but keeps going up to 70mph and would easy go faster. Once car is warm it starts fine and ticks over fine and sounds lovely oh and zero smoke, it also starts on the button once warm. Just while I'm waiting on this lead I thought I would update on the latest. Doe's it narrow it down at all?
Ben
Ben
#14
Posted 20 April 2012 - 08:08 PM
Glow plugs maybe. That's what I'm changing next. Does yours hit limp mode when trying to boot it?
MONDEO 2.0L TDCI 2004 (euro4)
#15
Posted 20 April 2012 - 08:12 PM
Well not sure if its in limp mode or not well under powered so it could be limp mode! no engine management light when booting it. Glow plugs would explain a bad start but this is really hard to start so i'm not sure its them.
Would faulty heater plugs cause the light to flash?
Would they put it into Limp mode?
Ben
Ben
#16
Posted 20 April 2012 - 08:49 PM
Faulty glowplugs don't give any warning lights. Flashing glowplug light usually a fuelling or turbo
pressure issue.
Yours sounds like fuelling.
pressure issue.
#17
Posted 21 April 2012 - 10:25 AM
Ben
Ben
That's exactly how my car behaved when the injectors were playing up and had "lost" their codes. Starting was very difficult with clouds of smoke when it did begin to fire.
Once warmed up it ran quite well.
Injector recoding was the cure in my case.
2002 2.0L TDCI 130 169,000 miles on the clock.
2007 2.0L TDCI 130 Estate 109,000 .......
Real Location: South Northumberland
#18
Posted 21 April 2012 - 06:43 PM
Quote
pressure issue.
pressure issue.
So when I start up in the morning and the car is lump and goes in limp mode and I get could light, that's not the glow plugs? What do you think it could be
#19
Posted 21 April 2012 - 07:06 PM
Fluidthegreat, on 21 April 2012 - 06:43 PM, said:
Quote
pressure issue.
pressure issue.
I'm no expert but I think £25 on a diagnostic lead seams the way to go , get some codes up then the experts can give you some advise like Mr Purple says Glow Plugs don't send it into limp mode. I would grad a cable off flebay and start from there. Maybe start your own thread
Ben
#20
Posted 21 April 2012 - 07:24 PM
Yea I think that's the way forward thanks
