Recent Topics
rear hub advice
2 replies to this topic
#1 chris zetec s
chris zetec s
  • 236 posts
  • Vehicle Driven:mondeo 2.0
  • Name:chris
Posted 14 April 2012 - 11:18 PM
can u fit caliper setup to rear drum hub?
bought full rear set up for disc conversion but snapped shocker bolt into hub an me m8s drilled it on an angle an fekd the hub up.
if i cn use drum hub (guessing u cnt) saves me some cash at breakers
cheers
mk2 mondeo 2.0 build. plans include frs engine
http://www.talkford....ost__p__1798013
#2 cozmium
cozmium
    Always busy with something...
  • 216 posts
  • 8 thanks
  • Vehicle Driven:Mondy Mk1 Ghia X 4x4
Posted 16 April 2012 - 12:53 PM
Can you not just compare the drum vs disc hubs if you have them both? If they are the same then I don't see why not, though i've never had drums so I can't speak knowing what they are like.
#3 stefdifranco
stefdifranco
    Stef
  • 27 posts
  • Vehicle Driven:Mondeo MK2 2.0L
  • Name:Stefano Di Franco
Posted 18 April 2012 - 02:52 PM
Hi I dont think you can use the drum hubs I couldn't on mine had to change both hub assemblys cost me £50 for a pair from a breakers yard.
This is what the hub assembly should look like for the calipers to be fitted
http://www.fordwiki....e:Reardisk2.jpg
